- supercharger disable
- Windshield wiper motor. Who knows wiring?
- Need help. Water temp sensor thread
- Steering column upgrade
- Weak Yota 3rd Members?
- Clutch bracket compatability?
- Who has a 2003 Tacoma v6 4wd with Auto Trans?
- 90s toyota drivability questions
- Power Steering Rack Emulating Ping/Chatter Sound?
- It's Road Trip Season What Should I Take?
- Zerk fittings on u-joint body impossible to reach? (Pic)
- Brake line question
- Power steering help?
- 1st gen spare tire stowage. What am I missing?
- I need a hand in Portland ASAP
- Never hawk pads!!!
- Coolant mixture percentage calculation
- 22RE engine...Stuff Everwhere?
- A Toyota frame help request seeking opinions or previous experience
- I'm stumped!!!
- Drivers side headlight burned out 3x in <1 year
- Using a Lincoln Air Compressor for On Board air
- Rust Reformer
- 3.0 Help
- Looking to buy a TLC 4Runner
- 3.0 Head Bolts
- 87 pickup running problems
- NJ Residents: inspection recommendation?
- Dropped socket in 3.0l
- Need help
- Cheap and Effective Exhaust Leak Detector
- Is this for real? $52 air locker
- Broken sun roof
- Way to reduce gap on hi-lift jack mount?
- 2.0 Coilovers: Fox vs King - Everything you need to know about selecting coilovers
- Links to Toyota offroad related websites & Toyota aftermarket parts vendors
- 8in V6 limited slip carrier in SFA questions
- 2001 highlander lift
- Name that sound: clicking from the rear, inside
- Newbie Question about IFS diff
- steering gear exploded?
- 92 toyoto 2WD 5 speed speedometer/odmeter not working
- Noise from the Bell housing!! Reman?
- Aftermarket parts for Toyota
- Honda Engine Rebuild
- Upholstry - Interior
- Mechanic - North NJ
- Engaging 4WD with Wheels Slipping.
- 22R Weber 32/36 float level
- Which 3.4 5VZ-FE do I have???
- 2011 dash tick behind guage cluster?
- Rust prevention
- 22R timing chain knock or rod?
- 3.4 high idle and cooling questions
- 22re distributor install
- Possible to add Rear Diff lock to 2wd 93 t100 truck?
- 2013 Tundra pulling right
- Things I learned about car seats
- My 4runner has leprosy
- Thermal insulation for ExtraCab
- Brake problem?
- New muffler more power
- See the T.V. ad and brochure for your truck.
- Hard to get into 1st and 2nd gear/ pedal slow return
- Grille and head light assembly
- 99 4 runner no start please help
- Looking to buy a Toyota 4Runner
- P0420 cat problem
- Surround for Lock Box - Do They Exist?
- Foamy bubbly oil in w56 manual trans after fluid change
- Buying a used toyota?
- Sway-A-Way 2.5 IFP Coilover Rebuild Instructions
- Sad Day
- ecu part#s dont match
- turn over no start, its unique
- Problem with my rear drum Brakes, Wheel locked
- What transmission is in a 1993 toyota t100 v6?
- Frost Fighter Wiper Defrosters
- spark plug extender
- Starting a "yota business"?
- Let's talk about loctite
- Boly Size 82 toyota pickup
- Brake work, now they drag
- Torque Specs on Cotter Pin-ed Nuts
- Thinking of trading down from my car to get back in a Runner.
- New headliner
- Need Help Figuring This One Out!
- MAJOR Fuel system upgrade!!! (IN TANK SURGE TANK)
- what Toyota or other comparable platform/mods would you pick to build a full time cam
- Ball joint seperator/pickle fork
- No power steering after hose repair
- DIY Paint Job - I CAN'T make it look worse, so no harm done.
- 84-88 Bed liner.
- oil loss-Im stumped
- Advice on a possibly bad 2TR-FE and shady dealer.
- Anybody ever have an axle housing rust through?
- Interior Clips
- Has anyone ever run a % of E85 to help pass emissions in an older vehicle?
- 2 Questions before heading to Alignment Shop
- No compression
- Why paint an engine?
- Rear disc brake conver. No E-Brake! HELP!
- Tried Lysol in vents need more help fighting mildew smell
- Center console parts
- 91 pickup or 96 tacoma sr5
- I need new drums, what brand would you purchase?
- No fuel or spark , 91 4runner 3.0 v6 ??
- Replica decals for older toyotas
- Misfiring or timing and backfires
- 22r vacuum hose from idle up diaphragm to ???
- 88 22r hard time starting! Help!
- Taco time?
- setting up distributor
- Brush guards, yes or no?
- Do TRD drop in air filters come pre-oiled?
- Cross Country Trip: Cali > Florida in a 91 4x4 3VZE: Should I be worried?
- Exhaust mani pipe gaskets (Flange Gasket)
- Toyota 92 22RE with Broken timing chain-
- rear axle problems, newbie, about to give up...
- Pulling a Travel Trailer with my Yota
- Has anyone seen what happens to sugar if it makes it to a gas tank?
- Roll bar fabrication
- 91 4Runner
- Broken P/S mount on block
- Gen 2 vs gen 3 4Runner
- Need a R-12 compressor
- Wrapping vs. Painting
- drive train question
- 1uzfe swap, speedo issue. who knows this ciruct well?
- What Diff fluid/Gear oil for base 91 *2WD truck* with small tires?
- Upgrade from 2nd gen to 3rd gen, or 97+ XJ
- My 4Runner Mods!
- stuck clutch pedal
- Can a Novice Install 22RE Rebuilt Long Block
- Hub choice
- Crank but no start
- I finally got hit.
- swapping a W50 trans for something else
- Opinions on rough idle/CEL etc. '88 V6
- 20R swap into 1990 p/u
- Need help, pickup/4tunner doors??
- Fuel Injector Replacements for FJ80
- Auto/Manual Conversion
- tuning AFM without a wideband O2 sensor
- Brake resivor sensor acting up?
- Engine problems, need advice
- Help me out fellas! Rear disc conversion
- I've created a terrible terrible monster
- coolant pipe for 22r
- Plasti Dip
- New clutch master and slave=race clutch?
- Violent Shaking When Starting off in 1st/Shifting into 2nd
- 2016 Toyota Vell fire
- Older Toy Pickup
- Doors!!??
- Which to buy
- Gasoline/PEA/Star Tron skin burns?
- Strange Noise
- 22R/R-E Clattering Noise at Cold Start/ Oil, Oil Filters, Timing Chain Tensioner
- Will this Weber fit my 22r???
- how much gas you have in your tank can lead to over heating.
- Suddenly dies for 1/4 second
- Parts compatibility database?
- body rust repair.. am i doing this correctly?
- 22R/RE Want oil pressure gauge. What peak reading?
- Would you sell your 90s pickup to DD an old Hilux?
- Nissan truck running rough
- New Fuel Pressure Regulator Acting Strange
- Recent Purchase '88 3.0 4X4 SR5 Xtra cab tune up questions
- Self tightening rear brakes
- FSM's - It's time to do this right
- Water in coolant, then no water?
- Any Midwest Toyota Dealers?
- Toyota 2.7L Valve Issues (Misfire related)
- Recording A Drive For Posterity
- A question about steering wheels
- Hacking a trail gear front bumper?
- fuel pump to carb fuel line kinking
- Need a reliable tech
- extreme cold problem
- Key fob questions
- Ignition switch stuck during cold weather
- Very Cold Weather and Brake Booster
- R150F Questions
- Toyota Red Coolant
- Anybody Interested In A 22R-G?
- Engine/transmission installment
- CEL Flashing
- weird fuel gauge.
- To fix what I have, or swap in some HP
- Using thread sealant in low temps
- Machine shops in Twin Cities area
- I'm baaaaack.....
- Identifying transmission
- Headgasket for 94 Landcruiser
- I'm Back - New Project '90 4Runner
- Potential to buy a 3rd Gen 4Runner
- Flame thrower install and long over due review W/pics
- Should i weld my rear end?
- 22RE Ticking....
- Horn only works when steering wheel is turned....
- rebuilt 3vze on craiglist? PacNor.
- Is there a difference between 3.0 and 3.4 thermostats?
- What year 4Runner?
- looking for a bigger cab
- new here - truck trouble
- Loud heater fan! Need help.
- How do people put different seats into their trucks?
- Improving brake pedal feel
- 84 4Runner canopy
- clutch engagement not good
- STP oil filters
- Any yota gurus near Pittsburgh?
- Is That Diesel Smoke? 2016 Tacoma
- winch set-up with trail gear winch plate
- Meet Canada's Downhill Warriors
- noise when take off in 1st gear only
- Engine tap. is it OK to drive long distance? (watch vid
- Engine revving uncontrollably
- Small lift, Big tires
- Need opinions for future buy - 89 2WD x-Cab $750
- what timing are you running on your rig?
- 81 20r Weber problems ,choke?
- How fast can I go with 4.70 tcase and 4.88 diff gears on 36" IROKS?
- 22RE engine swap
- What sizes tires
- Is it worth buying?
- 3.4 starts fine then quickly dies
- Coolant hoses
- VW TDI Diesel Swap Trans Selection
- 22r vs 22re Gas mileage?
- Anyone had an Optima battery? Any still going 5+ years?
- Thinking about buying a 1986 Toyota pickup
- Want to drive the world's most reliable car? Try a Toyota
- Beware at the Pump: E15 Ethanol approved by the EPA
- Crank seal groove, and other oil leak remedy caveats
- Gotta Love 22Rec engines.
- My 94 runner runnin poor
- 88 4runner rear window stopping 2 inches from the top
- Gasoline sabotage
- 7MGE stumbles and bogs down below 2000rpm
- Pulsating high idle. 3vze
- 10" wheels
- Urgent 4runner drifts to right, is frame bent?
- Allpro UCA group buy
- 4Runner Capabilities in Snow
- cars most like to cross 200,000 miles
- Rusty 3rd-how rusted is to rusty?
- How Reliable is the 3VZ?
- Stick shift mod needed
