stuck clutch pedal
Old Jun 2, 2015 | 10:51 AM
grayberts's Avatar
stuck clutch pedal
I have an 86 4 runner. Pressed my clutch pedal the other day and it depressed with a little resistence. After it released it would not depress again. The clutch is engaged since i can shift from gear to gear and roll the vehicle when in gear without depressing the pedal. Any ideas out there of what might be the issue????? Thanks from a yotatech newbie.
Old Jun 2, 2015 | 01:18 PM
wyoming9's Avatar
Red face
A little more back ground maybe??
Had things been working good up to this time??
Had your vehicle sat unused for a time like months ?/
For some reason weather something broke or has come apart or is stuck the clutch release bearing is holding the clutch plate against the clutch disc.
***Is the clutch bracket broke causing the Master Cylinder to bind ?? Since the pedal won`t move I would look into this first.****
Has the clutch slave cylinder vibrated loose and is now jammed unable to release
These are easy to see .
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
duncanmc
Aug 19, 2015 03:13 PM
Motomonty
Aug 9, 2015 05:53 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
