extreme cold problem
Old Feb 19, 2015 | 04:42 PM
mikeyd6789's Avatar
OK 84 Toyota pickup weber 32/36. Every time it gets in the teens....the truck cranks and runs super rich!...black smoke gas dripping out of tail pipe...overflow running into charcoal cannister and onto the ground. Warmer weather runs like a top. What the heck is freezing up??
Old Feb 21, 2015 | 02:17 PM
wyoming9's Avatar
Red face
Off the top of my head .
The needle valve is so stiff the float is unable to push it closed on the real cold days gets warm it works fine.
If your pushing gas out the charcoal canister vent hose line on wrong or the pressure in the fuel tank is so great it pushes out liquid the easiest path
Old Feb 21, 2015 | 02:54 PM
Terrys87's Avatar
Like wyoming9 mentioned. I see several return lines clogged as well. You cand check with a low pressure air hose. I dont use high pressure so as not to compress the clog. I fill the line with PB Blaster and let soak a few days and clear with an air hose.
Old Feb 22, 2015 | 01:46 PM
mikeyd6789's Avatar
Thanks for all the replies! Just got home from skiing in west Virginia. Pretty mild day here at home, truck fired right up. The only time I leak from canister is when it misfires and dumb fuel on those extreme Cold days. That's the only reason I don't think I have any clogs or lines clogged up. Is it possible the stiff needle valve could cause it to dump fuel and back up in canister?
Old Feb 22, 2015 | 02:37 PM
skypilot's Avatar
Needle valve in the carb is sticking. Time to overhaul it.
Old Feb 22, 2015 | 03:04 PM
mikeyd6789's Avatar
That's crazy. Weber only has about 800 miles on it.
Old Feb 22, 2015 | 11:59 PM
wyoming9's Avatar
Red face
Colder then normal temperatures can do strange things to almost any material.
The tolerance in the carb and the needle valve could be off just enough in the very cold to allow it to stay open.
Figure out why and fix it or just don`t drive in cold temperatures or just live with it and hope it does not catch fire.
Old Feb 23, 2015 | 04:36 AM
mikeyd6789's Avatar
Thanks for the help! I think I'll fix it haha. I'll order one today.
Old Feb 23, 2015 | 07:17 AM
MAINETOY's Avatar
Are you running a fuel pressure regulator?If not that may be your problem.
Old Feb 23, 2015 | 07:28 AM
mikeyd6789's Avatar
I'm not... but not having one would only cause trouble in the cold?
Old Feb 23, 2015 | 08:04 AM
wyoming9's Avatar
Red face
You say this Carb is new only a few miles.
Have you said anything about this problem to who you bought it from??
A new part may not fix the problem You need to know the cause .
Old Feb 23, 2015 | 08:05 AM
MAINETOY's Avatar
The stock toyota mechanical fuel pump puts out more pressure than the weber is supposed to run.And the cold probably makes the too much pressure even worse.
Old Feb 23, 2015 | 08:08 AM
MAINETOY's Avatar
Also is this a genuine Weber carb and not a copy?Thats another can of worms.
Old Feb 23, 2015 | 08:21 AM
mikeyd6789's Avatar
Yeah its a real one. Actually ordered it from amazon.
Old Feb 23, 2015 | 08:31 AM
MAINETOY's Avatar
What color is the electric choke?
Old Feb 23, 2015 | 12:52 PM
wyoming9's Avatar
Red face
I could see the fuel pressure being at the upper limits and with the cold being able to push past the needle valve.
Old Feb 23, 2015 | 01:21 PM
mikeyd6789's Avatar
That makes a lot of sense....I will look into that. Is there a certain brand or type of regulator you would recommend?
Flying91
45
Apr 11, 2024 04:39 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
ty1er
Jul 19, 2015 06:42 PM
Jonny246
Jul 12, 2015 04:51 AM
