3.4 starts fine then quickly dies
Old Nov 13, 2014 | 10:58 PM
FlashBucket's Avatar
96 T100, showed p300, p0302, p 0304; random misfire codes for 2 & 4. Plugs and wires are quite new, clean air filter, MAF, IAC, TB, cleaned injectors, swapped coils, etc.. Was running a little better until I ran compression test. (2 very low, 4 a little higher)
Put it back together and now it starts fine then suddenly dies after a few seconds. Fuel pump relay is clicking so it's not the EFI fuse I think. Triple checked connections and hoses, found a small tear in vapor purge line but nothing else. Any suggestions?
(Also is now also showing p0773, shift solenoid e electrical.) ???
Thanks
Old Nov 15, 2014 | 01:46 PM
Shoots! Pulled plugs again, had oil on electrodes. (??) Wiped it off, put em back and it ran for a min around the block. Parked it, let it sit and now it's cutting out again. Is this really bad??
zd92655
Mar 6, 2022 12:58 PM
Regency
20
Jan 3, 2020 07:43 PM
91toybeater
Dec 27, 2015 07:46 PM
ibayne
Jun 26, 2015 06:30 AM
slider417
Jun 22, 2015 10:18 AM
