Loud heater fan! Need help.
Old Jan 4, 2015 | 04:48 PM
88xtra4x4's Avatar
I've got an 88 toyota pickup, but I figure the problem can occur in any of the years. The heater barely blows when the fan setting isn't on "high" and recently when I turn on the fan it makes a loud sound like something isn't working correctly. The sound goes away and the heater blows normally after 45 mph. Any ideas? I really need the heater to work without so much noise.
Old Jan 4, 2015 | 04:51 PM
millball's Avatar
Take the motor and squirrel cage out and oil the motor shaft.
Clean the leaves and crud out of the heater plenum while you're in there.
Old Jan 4, 2015 | 05:27 PM
88xtra4x4's Avatar
Thanks for the information! I don't know where those are, but I guess that's what Google is for haha
Old Jan 4, 2015 | 05:44 PM
millball's Avatar
I thought you said it was noisy.
Turn it on and follow your ears to the noise.
Old Jan 4, 2015 | 05:48 PM
JasonYota's Avatar
A guess would be behind the glovebox.
Old Jan 4, 2015 | 06:07 PM
88xtra4x4's Avatar
I found a pretty good video in case anybody stumbles across this thread wondering how to access the blower motor and squirrel cage.
Old Jan 5, 2015 | 10:55 PM
wyoming9's Avatar
Red face
Pretty hard to miss!!
Old Jan 6, 2015 | 02:05 PM
88xtra4x4's Avatar
UPDATE!
I got my heater working correctly now. It was full of leaves and grime. Also there was a piece of plastic about 1 inch in size that was probably what was causing the noise. Not sure where the plastic piece came from though as my squirrel cage was perfectly intact.
Old Jan 14, 2015 | 12:42 PM
arlindsay1992's Avatar
That's my video. Hope it helps people out. I have a few other Toyota truck videos up as well.
Old Jan 14, 2015 | 02:00 PM
Terrys87's Avatar
If you had a lot of leaves in the blower assembly, most likely you AC Evaporator is full of debris as well. I would also suggest pulling the windshield cowl and cleaning the debris out of there as well.
Old Jan 14, 2015 | 02:24 PM
Terrys87's Avatar
Great job on the videos. I will look them up add them in my threads. Great Job!!!
Old Jan 16, 2015 | 06:18 PM
88xtra4x4's Avatar
Thanks for making such great Toyota videos! I am a huge fan of your tutorials. I have considered doing repair videos like this one too despite how easy some tasks can be, because some people simply have no idea how to do things on their truck.
Corvoid
Jul 4, 2021 11:51 PM
voiddweller
May 20, 2021 07:58 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Ohio4Runner
Aug 31, 2015 05:45 AM
g3bill2
Aug 7, 2015 07:04 AM
