Engine tap. is it OK to drive long distance? (watch vid
Old Nov 30, 2014 | 06:48 PM
jaysson_2012's Avatar
22r engine tap 84 yota: http://youtu.be/2xSlE1-JE0c
Is it OK to drive long distance? I live in NC for military and I came home to Kansas city to bring my truck back with me. When I got home the battery was bad. I had a LCE block off kit waiting for me when I got there. So I put the egr block plate kit in. And went and got a battery. When I started it it has a really loud tap. Wasn't there last year when I drove it last. Its a new engine from jasper engines of Missouri. I did not get to start it before I put the block off plates on so I don't know if they caused the tap or not. Please give me an answer quick! I'm driving it 1200 miles tomorrow unless someone says I shouldn't tonight!
Old Dec 5, 2014 | 01:49 PM
Ol'Greeny's Avatar
Have you ruled out an exhaust leak? They can almost sound like a tap, also make sure your valve cover isn't over tightened..hard to tell over video.
Old Dec 5, 2014 | 02:41 PM
I haven't yet. I think it might be a leak though because I noticed some carbon underneath the air injection block off plates.
Old Dec 5, 2014 | 03:07 PM
Ol'Greeny's Avatar
I had a small exhaust leak that sounded like a tap. I heard it under acceleration. But on deceleration it was quiet. And i could hear it at an idle.
If that's not the case you could use a stethoscope to help pin point where it's coming from. Like timing chain? Valves? Or bottom end.
Old Dec 5, 2014 | 07:03 PM
hoarder's Avatar
I am almost sure that is an exhaust leak. Mechanical taps are consistent, and that is not consistent, it varies. Hold your hand or a lit lighter around where you did the repair. You will feel an exhaust leak, or it will blow out the flame.
I would find that and repair it before you drive 1200 miles!
Old Dec 5, 2014 | 08:18 PM
Well I already drove it the 1200 and it ran great. The tap gets louder under a load, or acceleration. I look into the gaskets tomorrow. Hopefully it kills the taps!
Old Dec 6, 2014 | 04:13 AM
hoarder's Avatar
That pretty much confirms the exhaust leak. Glad you made it
arlindsay1992
Jan 23, 2024 01:34 PM
Ichneumon
Sep 27, 2015 04:21 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Old Red 94
Jun 16, 2015 08:32 PM
