Ignition switch stuck during cold weather
Old Feb 17, 2015 | 04:01 PM
MorphiasX's Avatar
I have a 1990 pickup, that has started having trouble with the ignition switch key cylinder not wanting to turn when it has been sitting in the cold. By cold I mean below freezing, usually single digits or teens with wind chill below zero at times. I put the key in, and it doesn't want to turn kinda similar to the feel of the steering lock, but it does it when the steering wheel is not locked. After wiggling the key for a while, taking it in and out a few times, it will turn like normal. Has anybody else had this issue? Is it just worn and in need of being replaced?
Old Feb 17, 2015 | 11:49 PM
Odin's Avatar
You might try disconnecting the battery, squirting Tri-Flow in the switch, inserting the key and working it back and forth several times. I usually do that with sticky house or car door locks and it frees them up nicely.
I did it to the sticky ignition switch on my 91, so far no problems to report.
Old Feb 17, 2015 | 11:55 PM
wyoming9's Avatar
Red face
What the All Father said!!
Have you ever lubricated the switch or door locks??
Old Feb 18, 2015 | 03:30 AM
MorphiasX's Avatar
Thanks for the advice, I just sprayed Tri-flow in both the door cylinders and the ignition cylinder, the test will be when I leave work today to see if it helped, the high is 25, and it will be dropping throughout the day, supposed to be 11 degrees plus windchill when I leave work today.
I have never lubricated the lock or ignition cylinders, the truck has been in Southern California its entire life until 2 years ago, they never had trouble there because it didn't get cold enough I guess.
Old Feb 18, 2015 | 07:08 AM
Odin's Avatar
Sometimes it takes a few applications. The drivers door on my truck was the worst I've ever encountered. After several applications of Tri-Flow it works quite well.
Old Feb 20, 2015 | 05:29 PM
Odin's Avatar
Well did the Tri-Flow work for you?
Old Feb 21, 2015 | 01:23 AM
wyoming9's Avatar
Red face
I use Kroil
Lock cylinders are moving parts they need to be lubricated from time to time.
Not being lubricated is what causes them to wear.
Old Feb 21, 2015 | 12:03 PM
Odin's Avatar
That could work too.
I can't easily get Kroil and it's fairly expensive for what it is.
Some locksmiths sell Tri-Flow and I can easily purchase it at other places so I use it.
However when dealing with rusted up stuff I have thought about purchasing some of it because PB Blaster isn't the greatest.
Old Feb 21, 2015 | 02:19 PM
wyoming9's Avatar
Red face
Anything is better then nothing at all even WD40
80Truck
Oct 12, 2025 07:25 PM
fountain
Dec 31, 2015 06:08 AM
redneck17
Aug 12, 2015 08:15 PM
TDonkey
Jul 26, 2015 10:14 AM
colinmil
Jul 6, 2015 04:03 PM
