PDA
View Full Version : General Vehicle Related Topics (Non Year Related)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. 5.0 fordrunner SWAPP!!!!???
  2. 22r 85-88 for sale with trans manual
  3. Need O2 sensor help on 22R please???
  4. Trying to inport diesel toyotas from poland HELP
  5. pvc hose on 2.4 diesel w/turbo
  6. The moon rover is up on blocks again
  7. Maryland Title Issue with a 1987 Toyota 4Runner
  8. Has anybody ever hauled a light weight cab over camer on a Base 2wd 22re?
  9. A Love Reborn!
  10. how to change brake pads and rotors?
  11. Help me pick my next Toyota?
  12. 90 IFS lift fit an 87 pickup?
  13. Aftermarket body parts 79-83 yota pickups?
  14. 91 toyota p/u
  15. to fix or not to fix, that is the question
  16. Dry ice…..my new best friend! works wonders for removing sound deadener
  17. Fuel Tank Compatability
  18. aftermarket cam
  19. Help deciding on wheel paint
  20. 22re Knock Sensor Wire replacement
  21. Rear bed liner with herculiner
  22. Upgrade Exhaust?
  23. Mechanical Speedometer gear not engaging in transmission
  24. 22r head gasket on 21r
  25. stalling problems
  26. too much oil
  27. 98 4runner Not starting
  28. 1998 Toyota 4runner Clutch fade
  29. high steer
  30. high steer
  31. Electronic Carburator
  32. Anyone ever make an alternator cover?
  33. Australia, diesels, shipping
  34. '94 Tercel?
  35. DANA 60's and 38" ONLY 4:10s?????
  36. Scrubby’s for paint preparation
  37. Buyers beware.
  38. 22r intermitten no start mostly when hot
  39. Knock Sensor -- When does it throw a code?
  40. Calling All Photographers
  41. Oiled Air Filter Maintenance -Simple Green Method
  42. How to stop dash cracks
  43. Pilot bearing removal the ez way!!
  44. Timing Chain Parts Dilemma
  45. Idle/Fuel Cut Solenoid Bypass
  46. Clogged EGR Clear out or remove?
  47. Talk about not wanting to sell your ride
  48. tube doors street legal?
  49. Rav4 opinions
  50. 22r using oil after rebuild
  51. Highlander sunroof drain tubes - where are they?
  52. LC Engineering Summer Video Contest
  53. U-Joint question, Yolk wear.
  54. 98 Taco removing engine w/tranny
  55. Dealer may have used wrong oil
  56. 3.0 exhaust questions..
  57. Something smells bad when I accelerate???
  58. 77 hilux gas tank
  59. 1985 Trail rig value
  60. check for damage, drove in 4wd on hard pavement, '87 4runner
  61. Identify this trans? (Marks 4wd adapter)
  62. Clean debate wanted: MPG vs. Accelerator pressure.
  63. Rebuild cv axles
  64. What to charge for a truck that needs a new engine?
  65. Another Question on how to adjust valves?????
  66. Thrust Angle Off by 0.3 degrees
  67. ultra low gears?
  68. Mystery Idle problem
  69. 1994 4runner doors on a 93 p/u
  70. Cab removal with only 2 people, a High lift, and come along
  71. question about connecting rod bearings????
  72. Dropping the oil pan, Should I replace the Rod bearings?
  73. Who WOULDNT buy one?
  74. Question about oil pan and timing guides??
  75. Preventative Maintenance
  76. Help with part identification
  77. How Do I use the Plastigage on my 1991 Toyota pickup?
  78. What size are these tires?
  79. Weber Air Filter
  80. CB Radio Interference
  81. Broken water pump long bolt
  82. AutoZone FA5040 idler arm
  83. 91 doors
  84. Body work question-Pits in bondo
  85. Importing Parts to Canada
  86. What is this part?
  87. Wooden shift knob?
  88. 1st Gen Taco Buying advice/opinion
  89. 22reperfomance.com for parts
  90. 20r distributor
  91. Do it yourself straight pipe
  92. My first major powder coat job at home.
  93. Helicoil Questions
  94. might be selling 84 4x4 but need help.
  95. Made a digital inclinometer + altimeter
  96. painting the frame n stuffs
  97. toyota turbos swaps
  98. 4runner Supercharger?
  99. Hi guys! New Toyota Pickup owner here! Could use some advice!!!
  100. 2007 4runner rear rotor removal
  101. A/C control knob
  102. '95 Taco 2RZ-FE throttle body adjustments
  103. Blown ifs power steering boxes
  104. Rebuilt 4runner Advice
  105. To Gauge or not to Gauge !!
  106. Seat Cover help!!
  107. Let's see your rust repairs! I need motivation.
  108. help, engine/fuel delivery issue
  109. improving my 3vz engine
  110. Junk Yard Yota's
  111. Trail Gear "authentic" Longfields....Not real
  112. Connector identification / what is this connector for?
  113. sweet aussie Hilux
  114. Profit I can expect from partout?
  115. 1st gen custom climate controls help needed.
  116. Post your FLATBED pics
  117. Switching to synthetic in trans - flush needed?
  118. OME Lift kit question
  119. Excessive clutch free play
  120. Hit a pole.. Now what?
  121. fuel pump location 2002 4 runner 3.4l
  122. about cartridge filter?
  123. Best year to buy a 4wd diesel 4runner
  124. Which cold air intake???
  125. 4 runner rear springs
  126. Which lunchbox locker to get?
  127. alternator fault?
  128. Towing more than the specified capacity
  129. Will synthetic double the oil change intervals?
  130. Water in oil and oil in coolant system
  131. the top ten 200,000 mile vehicles
  132. Cheapest place to find lug nuts?
  133. Highway driving a Dual T-case Rig?
  134. Rust repair and rocker guard paint.
  135. frame identification question...
  136. Lower mileage 3rd Gen vs higher mileage 4th Gen 4runner
  137. Poor traction in snow
  138. Les Schwab wont touch my brakes
  139. 1993 Toyota pickup - Head gasket repair
  140. Engine wiring harness question
  141. 4runner or land cruiser
  142. 91 4Runner overheating
  143. 1986 toyota pickup bucking
  144. Four wheel activation
  145. 22RE completely dying out
  146. 1st gen Tacoma bumper height
  147. Brake drag?
  148. Need Quiet Muffler
  149. Hard brake pedal when cold
  150. Brakes hard when cold
  151. Brakes pedal hard when cold
  152. Wiper arms/adapters ans blades
  153. car backfire and stop while driving
  154. LockingHubs and ADD
  155. "Andy Mod 2.0" Complete, But noisy start-up in 4 Low?
  156. Possible fj 60 purchase
  157. Rear Suspension Overhaul
  158. Mississippi winter storm
  159. Ignition/door lock swap
  160. Banjo Bolt Deliverence
  161. Driving in 4x4 Mode When Not 'Needed'
  162. Pulled engine - desmog, new timing chain, new engblrdr 268 cam. Poor performance.
  163. Clutch is sticking from being dirty. Is it fixable?
  164. Moving fuel filter location.
  165. 22R Knock and Mysterious Grinding Noise
  166. For those who remove doors/use tube doors on occasion.
  167. Diesel Tundra
  168. top 10 to look for when buying a toy pickup
  169. Post Your Favorite Vehicle-Related Stories!
  170. gears meake noise
  171. San Diego Recommended Transmission shop for 2000 Toyota 4Runner?
  172. Jack stands
  173. How to Plug Vacuum Lines? Recommendations
  174. turbine rims
  175. Rock sliders
  176. TPS Adjustment 1996 Rav4
  177. How do you know when it's to much !!?
  178. Catalytic Converter Theft
  179. cooling system question
  180. Tacoma rear locker frozen
  181. 04 Toyota Tacoma under cover
  182. Brake Help
  183. So my engine is toast.....
  184. yotatech saved my ass thanks
  185. 91 Pickup 22re piece of oil dipstick stuck in tube
  186. best way to upgrade brakes?
  187. Radiator Leaking into Transmission 1999 V6 4Runner SR5
  188. Paint
  189. Rear Window Slider Airflow With a Camper Shell?
  190. Nardi wheel finally installed
  191. Good place to buy a W56
  192. Help me remove my body lift: Seattle Area
  193. 79 toyota with 2l diesel
  194. stranded again for a while....
  195. Dumb Frame Reinforcement Question
  196. Hub leaking
  197. Transmission Leak!
  198. Gas mileage is horrible.
  199. Has anyone tried the reproduction carbs?
  200. warn winch input!?
  201. Gear setup...
  202. blown spark pluk burnt boot falls in HELP
  203. tire and bed size for different year models
  204. Too much Vacuumn
  205. Is 95 t100 gas tank interchangeable?
  206. 22R series coolant system bleeding
  207. Brake bleeding help asap
  208. Fun times.. proven bullet proof once again
  209. Setting up a diff
  210. Truck Specs From Vin?
  211. Dueler Revos
  212. volt light and brake light on after webber carb install??
  213. webber carb install32/36 no start now
  214. Transmission?? Vibration/Rumble
  215. 86 22RET turbo pickup
  216. Dually taco
  217. Hesitation and headlight and battery charge meter flickering while accelerating
  218. What's the best insurance for a Toyota Tacoma?
  219. Major Props to Toyota: Vetrans Day
  220. Pin Stripes/Decals
  221. A couple general 22re questions,(while rebuilding top end)(pics)
  222. Lifted Vehicles Headlight adjustment.
  223. FYI How I removed my stubborn Rear 3rd
  224. Junk yard find.
  225. Shock Specs
  226. seting up gears
  227. Dupli Color Bedarmour kit
  228. 2013 Toyota Tacoma4x4
  229. Trekker spotting in North MS!!
  230. Price and other info on FJ40 Landcruiser
  231. good Yota shop Phoenix metro area???
  232. Follow-up on previous thread on Yota project truck.
  233. So my wife wants a Highlander...
  234. What bumper is this??
  235. Anyone know what kind of trans this is?
  236. Is RUF mod still best if you gotta buy the springs?
  237. Price paid 2014 2013 LTD 4runner
  238. third member setup specs
  239. What is this shock for??
  240. Amazon ball joint spacers
  241. something broke in my rear end...
  242. spare tire rim on 2007 RAV4 limited
  243. A big Thank You
  244. t100 upgrade thread
  245. 2004 toyota sienna AC not working
  246. Odd brake pad
  247. Chasing head bolts
  248. I broke my engine.
  249. D.I.Y. bedliner recommendations.
  250. Replace 22r piston rings
