Hard brake pedal when cold
Old Feb 8, 2014 | 06:33 AM
PoindexterS's Avatar
Any suggestions as to why when cold (below 15*f) at start up and first braking my pedal is super hard to push and truck does not want to stop. After the first stop or if I push-release and push again it softens up and acts normal. Only does it when really cold and at first braking.
Old Feb 8, 2014 | 01:24 PM
MB4runner's Avatar
Common problem is the vacuum check valve.. .Replace the vacuum check valve on the brake booster. It's a one way valve that gets stuck and doesn't allow vacuum into the booster. I've had two toyotas that did this.
Old Feb 8, 2014 | 11:21 PM
Terrys87's Avatar
I would also make sure the fluid is flushed out and new fluid added. I seen fluid that is probably the original fluid from the factory.
fountain
Dec 31, 2015 06:08 AM
Backcountry411
Jul 24, 2015 08:06 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
