So my engine is toast.....
Old Jan 2, 2014 | 05:40 AM
The General's Avatar
my '01 Limited had 230k miles (in great shape and well maintained) and I had the family packed in and coming back from Christmas vacation, engine started knocking and died about a mile later. Dealership told me I needed a new motor, said they dropped the oil pan and there were metal parts in there. So two questions: 1) Should I get a rebuilt engine installed or buy a used engine with 80k miles? Or is there a chance a good mechanic can go in and fix what's broken and a different engine is not necessary. Any help is appreciated, thanks.
john
nashville
Old Jan 2, 2014 | 03:45 PM
rokblok's Avatar
Was the cause determined? Low oil or coolant? Part failure? How long did it knock before you shut it down? Or did it seize on its own? What are the metal parts in the pan? Rods, bearings, piston chunks?
I would suggest finding a rebuilt short block. Yours may be to far damaged to be worth saving. I'm not a fan of used unless I can see the maintenance history, and partially disassemble to inspect valves and cylinder walls.
Old Jan 2, 2014 | 04:10 PM
lobukbuild's Avatar
shortest route would be a reman short or long block with a warranty. other than that you just dont know what youve got unless you can hear and test a used motor be fore you buy it and see the vehicle it was in to verify the mileage.
Old Jan 2, 2014 | 04:38 PM
rokblok's Avatar
My apologies, I meant to type long block. You are correct, Lo.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
