improving my 3vz engine
Old Mar 18, 2014 | 12:20 PM
workhorse396's Avatar
i looked through the threads and couldnt really find what i was looking for. debates about the 3vz engine and trash talk. yes, id love to do the 22r swap on my wifes 94 4runner but dont really have the funds so after i do the top end rebuild cause its got 200k for miles and smokes like cheech and chong. what can i do to improve the engine and make it preform better without having to do annual rebuilds. she loves to get her rig deep int he mud but i have a laundry list of work to do before hand. any and all guidance is welcome and very much appreciated.
thanks all.
Old Mar 18, 2014 | 12:24 PM
probably would help if i included what the heck i was talking about. its a 94 4runner with the 3vz-e engine. both head gaskets are blown and i wanna do the top end rebuild so it will last her muddy abuse and i really wanna avoid any risk since she usualy transports our daughter in it too.
Old Mar 18, 2014 | 01:17 PM
95blackToy's Avatar
Would be good to put headers or do a crossover elimination to the exhaust, will help with the head gaskets.
If your doing a top end rebuild you should also have your injectors redone
Look up witchhunter injectors or something like that, I think it was like 25 an injector last time I had mine done.
Old Mar 18, 2014 | 01:29 PM
thats really cheap considering i cant find oem injectors for under $90 at walk in price. i was curious if you can do that stupid cross pipe elimination. i was told by a toyota dealership tech i had to replace the water pump and timming belt. i always change the belt if i remove it just to be safe but is there any truth to the water pump statement? if you wouldnt mind confirming the injector name id be much appreciative.
Old Mar 18, 2014 | 01:42 PM
95blackToy's Avatar
http://www.witchhunter.com/
Water pump is easy if yor already doing the belt, the water pump doesn't fail that often, but would he good maintenance especially if your doing the belt.
Cheap piece of mind.
I'm putting headers on mine. They are expensive, but hopefully well worth it. In the process right now.
Should also put all new coolant hoses, and do the normal plugs, wires, cap and rotor
Old Mar 18, 2014 | 02:20 PM
oh yea im gona do the norm cap, rotor, plugs, wires, belts, water pump, timing belt the usual. is there a exhaust manifold i could pull of a different model at the junk yard that would delete that cross pipe?
Old Mar 18, 2014 | 03:16 PM
95blackToy's Avatar
No, search crossover elimination, have to cut and weld. Or spend the cash for headers. Will be easier since you can remove crossover with heads off.
Old Mar 19, 2014 | 07:15 AM
ok well welding wont be a issue i'll look it up. thanks.
Flying91
45
Apr 11, 2024 04:39 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
garagespace
Jul 9, 2015 08:37 AM
