Blown ifs power steering boxes
Old Mar 27, 2014 | 08:58 PM
Neil McCon's Avatar
So in the last couple months I've been through 3 different boxes. I'm not completely sure where its coming from but it seems to me that its from the top cover that has one center nut with a stud in the the middle (slot in center) and four bolts which holds it down. Is it possible to come from there and could i just remove it, clean it and put some rtv on it? Or is a internal seal that allows it to leak up and out from there? Im sick of paying from 50-100$ for these damn boxes and a few hours of swapping them. Very frustrating. I believe its from my pump because a little after doing my sas the pump began to squeal so i believe it could be the cause. Thats when i dirt began blowing the boxes? I'm not positive on anything but really need your guys help!!! Please and thank you.
Old Mar 27, 2014 | 10:59 PM
wyoming9's Avatar
Red face
Have you checked your pump pressure??
Then I take it your put used boxes on??
Which are about the same age as yours most likely sitting unused for years seals dry out start leaking.
Well you have all those that leak pull one apart get new seals put them in .
Remember that the surface of the shafts the seals ride on must be clean and smooth.
Things do wear out
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
keithporter83
Jul 24, 2015 07:37 AM
scottyg486
Jul 19, 2015 05:34 PM
jon.r
Jul 11, 2015 03:34 PM
