PDA
View Full Version : General Vehicle Related Topics (Non Year Related)
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Highlander Oil Filter Debate: OEM 04152-YZZA1 vs. TRD Filter
  2. mystery step side need fender flares
  3. Yet Another Undercoating Thread
  4. Cressida/supra lsd
  5. Cressida/supra lsd
  6. Is my 22R really stock?
  7. Identify these seats
  8. Winter /Liquid Brine Gotta love it.
  9. 83' 2L diesel 4x4 build - suggestions needed
  10. see your hunting trucks!
  11. First Toyota Pickup Dos/Don'ts
  12. Tips for Mileage Improvement?
  13. Fixing The SR5 cluster
  14. 79' 20r wont stay running!!
  15. Blue Smoke All of a Sudden
  16. Sr5 gauge bulb holders
  17. Drove first 3rd gen - surprised by lack of pep - seems heavy
  18. Sticky, nasty mess!
  19. Starter won't crank
  20. how can i get some lift in the front end of my 04 tacoma!
  21. Lift Kit Explanation Please...
  22. A/C complete redo
  23. 98 4runner transmission code p0753
  24. Quick easy question - bumper rust
  25. Knock After Overheating
  26. Timing issues....22r
  27. pickup starter issue?
  28. 22R electric choke
  29. 98 Taco 3RZ Coolant Drain Plug
  30. Help some one stole a part off my truck and don't know what it was
  31. 4runner help
  32. brakes.
  33. Make a fellar cuss on a Sunday morning
  34. Need help brakes in front stick
  35. Your must-have truck accessory
  36. post your pics 84-88 4runners
  37. How to Check 22re Timing Chain Alignment?
  38. looking to buy this 1st gen hilux surf... questions
  39. Which one should I get???
  40. best place to shop
  41. Which Yota to sell?
  42. Towing my truck.
  43. Where is this leaking from ??
  44. Clearing the code fixes?
  45. Shrockworks group buy
  46. Gas tank cleaning and sealing.
  47. Size of Backspacing and center caps
  48. New Owner of an '85 4Runner
  49. pre swap, engine break in questions
  50. 1uzfe + a340f not shifting
  51. After market fan
  52. To RTV or not to RTV?
  53. Toyota Reliability and Durability
  54. New bumper...tons of rust spots from rain!
  55. 93 p/u -$700- shall I pick it up?
  56. 4th gen 4runner vs 2nd gen Tacoma
  57. Odometer / DMV error?
  58. VIN research...
  59. Where can I find a Toyota Pickup for <$1000?
  60. No a/c at idle.
  61. Power-train overhaul & 4x4 conversion (Sunrader RV)
  62. speed sensor melting & flattening gears
  63. valence bolt size?
  64. AFM Question
  65. FJ60 1984 Toyota Land Cruiser
  66. Toyota noob needing some opinions
  67. starter possibly
  68. Idle is poop
  69. Replacing a failing AC compressor
  70. 1992 R150F Spline Count
  71. IFS Brake Caliper Question
  72. Yota shop?
  73. help me biy my first toyota!
  74. need help
  75. Road trip check list
  76. Shop that refubishes Aisin hubs.
  77. 1st gen 4runner clear turn signals (front)
  78. Should i be disapointed i have a petrol hilux?
  79. Remove unneeded EFI fuel pump?
  80. bilstein suspension advice
  81. Frame straightening
  82. marlin crawler
  83. Yota Newb
  84. Toyotapartseast no longer has parts diagrams
  85. 1988 Factory Service Manual
  86. Any issues with those zip-tie transmission cooler set-ups for the 3rd Gen. 4Runners?
  87. Video of my 1st gen mudding
  88. Opinions on buying aRav4
  89. Is a Trekker a 4runner?
  90. help with mpg.....
  91. Engine Rebuild: Need Some Advice
  92. leaf springs
  93. Need input on Tires!!!!
  94. Clutch & RMS swap advice.
  95. MSD 6A on 22RTE
  96. Short or long tube header for an 85 22r 2wd
  97. 3/4 link calculators
  98. outer birfield c clip help
  99. weird sound when push brake pedal all the way (sometimes)
  100. Fuel pump not kicking on? 63 install.
  101. wanna see a Chinese 4Runner?
  102. Odd Engine Function
  103. driveshaft removal
  104. TOYOTA Towing
  105. Radio Reception Problems
  106. Interior Paint
  107. Figuring out these odd placed hoses
  108. Seat conversion
  109. aisin carb look a like?
  110. What rear end is this? 7.5?
  111. Engnbldr
  112. Crazy what you find cruzing the crappy part of town...
  113. Dimedout's Center Console Build
  114. how much gear oil
  115. New speeodometer gear fails after 100 miles
  116. In search of half doors
  117. Accidentally put in reverse 4 runner.
  118. How often do people offer to buy your Toyota pickup? :)
  119. Plastidip hood scoop
  120. air flow sensor issues
  121. Flange to flange length of '86-'95 IFS differential
  122. Glass Lite Toyota camper shell
  123. Brake hydraulic castings!!!
  124. If you're looking for a swap, this is DEFINITELY one to consider.
  125. Right Rear Oil Seal and Bearing
  126. What does your yota weigh?
  127. Sloped vs vertical valve covers: what year did it change? 83 or 84?
  128. Need replacement aisin manual locking hub part.
  129. Door and window gaskets 86 yota
  130. Fuel Vaporizer for better MPG
  131. 22re won't run over 1500rpm
  132. When to change dual row timing chain
  133. What tires ya running?
  134. How long will 22R & RE engines and other parts on Toyota pickups last.
  135. Toyota Red VS. Pink coolant / anti freeze
  136. Alcan leaf spring owners: looking for insight
  137. CAPA Parts $$$
  138. leveling kits 2000 tundra 4x4
  139. 3rd gen Radiator in a 2nd gen?
  140. emissions diagrams
  141. Taro/Hilux 2WD Cab on 4x4 frame?
  142. 01 Sequoia Cruise control kicks off
  143. Engine advice. Swap or rebuild? Thats the question.
  144. Arb rear? Spartan front opinions?
  145. Damn calipers...
  146. Help identify thingy on 3MZFE (2005 Highlander)
  147. over drive button?
  148. York Onboard Air with A/C
  149. Door interchange
  150. Looking for large modern toyota logo decal (link in my post)
  151. Spring Spacers vs. Coilovers
  152. How to Repair Torn Seat (Side) ??
  153. Starts cold then wont start gremlin 3.4L
  154. what color should i paint my 84? pics needed
  155. 1990 22re truck vs. 4Runner?
  156. LED Halogen Headlights
  157. 3.0 starter problem.......
  158. body work
  159. 1998 4 runner starter issue
  160. Mazda AFM?
  161. Roof Rack Rails! Will 2nd Gen Rails fit my 3rd Gen???
  162. Tow Rig and Trailer (Post Pictures)
  163. 4x4 low issues?
  164. automatic tire deflators
  165. Reputable company for crate motors/longblocks
  166. Toyota 2015
  167. 88 4wd Interior Carpet
  168. HELP: Need opinions for removing rust and doing body work please
  169. Question: How to remove hose clamp in tight quarters?
  170. Front end damage/ Frame slightly bent
  171. 2.4 2lt diesel
  172. 2005 Toyota Tacoma Vibration
  173. lubricating the rear window and motor?
  174. Question about the driveshaft slide yoke
  175. High beam lights are not working in my 1990 4Runner
  176. Finished my door panels.
  177. EFI or carb for poor quality fuel?
  178. Just picked up a 1986 toyota 2wd 1 ton pickup
  179. 6th Generation 4Runner. Is the 4Runner Dead in 2016?
  180. SR5 cluster swap issues? Did you have any?
  181. Gasket Removal Help: Is This OK?
  182. ordering Toyota parts
  183. Acronym for TOYOTA
  184. 1996 Tacoma AC Expansion Valve Differences
  185. Looking for a throttle cable. any ideas?
  186. Give me some feedback.
  187. Anybody seen this before?
  188. 22ret bellhousing!!!!!!!!!
  189. 22r conversion
  190. Supra motor swap price question
  191. Harbor Freight 12v dual horn kit
  192. New vehicle/project: 1993 Toyota Pickup *4x4 conversion*
  193. hydro assist fluid
  194. A340H vs A340E? Help ASAP!
  195. Lc 70 series colour codes
  196. where to cut holes for dual case shifters 87 4runner
  197. Injector works... Then doesn't.. then works again.
  198. bad alternator or battery?
  199. How's my gear pattern?
  200. Best no-welding projects
  201. 1988 4runner vs 1995 Landcruiser
  202. End of a love affair.......
  203. Catalytic Converter Theft UP in Arizona
  204. Bobby Long
  205. I need a picture
  206. Krikit V-Belt Tension Gauge Experience
  207. Electric power steering?
  208. Transmission to Transfer Case Adapter
  209. 3.0 to 22R-E?
  210. 22-RE problems
  211. replacment bed suppliers (list)
  212. It seems like 4runners are a more popular platform for offroading than trucks. Why?
  213. useful site for finding parts
  214. Increase in '97Rav4 Gas Use
  215. car hauler trailer questions ?????
  216. way too much fuel #3 & 4
  217. 22re exhaust studs
  218. 99 4runner vs 88 4 runner
  219. High beam lights are not working in my 1990 4Runner
  220. Deal of the century
  221. Overhead console
  222. Chaing interior color
  223. 1992 4Runner 3.4 auto swap (WAY in beginning stage)
  224. 4:88 gearing
  225. Shocks causing stiff ride
  226. Broken IFS steering box?
  227. Gonna get wet and muddy!
  228. ENGNBLDR RV head arrived!!
  229. Exhaust guru's enter...22re lc header restore.
  230. ccheck engine
  231. HELP! 1994 3VZE: Temperature Sensor (Code 22)
  232. wait a second.... this isnt right....
  233. 95 3vze issues
  234. rear disk brake swap
  235. How awesome is Toyota??? Awesome!!!
  236. Helpppppp urgentt !!!! Rhd parts wanted
  237. 4runner 1990 and the 1994 water problem help
  238. bed liner question
  239. 20/22r exhaust sucking in
  240. Flood damage
  241. I need to buy a toyota midsize truck with back seat
  242. Rear e-locker in fjz 80 axle not disengaging
  243. "Prado SXE" diesel?
  244. Por-15
  245. Bilstein 4600 vs bilstein 5100?
  246. 4cyl Thirds
  247. What happened to Sea 2 Sky tuning??
  248. Squeaky A arms!!
  249. After Market Steering wheel recommendations--diameter wise
  250. Performance 2RZ/3rz
