Gas mileage is horrible.
Old Dec 8, 2013 | 08:11 AM
FinishThaGame's Avatar
1994 P/U 22re (with 36,000 miles on engine). Alright, i am tired of getting 13-14 mpg, i believe i have a vacuum leak, because i get alot of idle surging as well as bucking in 1st gear when gas pedal is barely being pushed.
Now, i am running 35's and 5.29's but i would think if the engine is running tip top that i should get close to 17-18 mpg, any one that has a similar truck or experience with this issue plz chime in, its breaking my bank as this is my DD and on average i drive 60-70 miles per workday Mon-Fri and am spending 80-100 dollars per week.
Thanks yall
Old Dec 8, 2013 | 09:28 AM
ksti's Avatar
Thanks yall
Have you ever changed the upstream o2 sensor?
Old Dec 8, 2013 | 09:39 AM
No. Code does come up on reader. I didnt bother cause there is no Catalytic Converter, so wouldnt it be a waste without that?
Old Dec 8, 2013 | 10:47 AM
ksti's Avatar
Code reader?, 94 should be a OBD1.
A paper clip on diagnostic port TE1 and E1 should show constant flashing for no codes stored or pause flashing, indicating a code stored.
So is there a o2 sensor even on it?
Old Dec 8, 2013 | 06:09 PM
chrisgreene243's Avatar
What sort of tune ups/ repairs have you done to it recently?
Old Dec 9, 2013 | 01:59 AM
I believe you read it wrong. When i said NO i was answer your question about weather or not i replace the upstream O2, and the answer is NO. I was also letting you know that a code does show up and i cant remember if it was O2 code or catylist system..... And yes it is OBD1. There is an O2 sensor after where the cat would go, so i guess that would actually be down stream. I will check if there is an upstream.
Old Dec 9, 2013 | 02:01 AM
Please check my build thread. The truck has been doing this since i got it. But i have had alot of other issues so im finally getting to this one. Ive had the truck for around 6 months.
Old Dec 9, 2013 | 06:03 AM
ksti's Avatar
I did read it right, I was questioning when you mentioned "code reader"
Just seemed odd on a OBD1
Old Dec 9, 2013 | 07:40 AM
My bad. My mechanic friend looked at it and told me that it was throwing some kinda "exhaust, oxygen trouble" i honestly dont know the method he used bro. All this stuff is new to me, so i learn as i go.
Old Dec 9, 2013 | 08:54 AM
wyoming9's Avatar
Red face
With those tires and the wind resistance under the lifted truck your mileage will suffer.
Get some smaller tires if your commuting every day.
remove as much weight as possible.
Buy a car or Bike for going to work.
Old Dec 9, 2013 | 09:51 AM
Terrys87's Avatar
If you dont have a California model, it wont have the O2 Sensor behind the catalytic converter so that wouldnt cause you a problem. I have fixed alot of problems with just cleaning the Plenum ( actually doing that now>>> https://www.yotatech.com/forums/f199...l#post52146627 ,pages 81 and 82 ) a great tune up using high quality parts, making sure there are no leaks, testing all sensors and giving them a good cleaning as well. Most likely your O2 Sensor is orgianal and would need to be replaced as well. I have gotten away with cleaning the O2 sensor.
I get my Denso plug wires off of ebay, plugs, cap and rotor from Toyota, and get the part number off of www.sparkplugs.com and use that part number for the O2 sensor on ebay for a little cheaper.
I have alway been able to clean an EGR and get rid of the codes that way. Never had to replace one yet, but it might not would pass emissions but I have never had a problem after cleaning one.
Old Dec 9, 2013 | 10:27 AM
Thank you Terry, im at work now but when i get home i will go through that thread and read it. All ive done so far is replaced the plugs.
Old Dec 9, 2013 | 01:03 PM
This toyota was built in Japan, and i see no indication of it being from California.
Old Dec 9, 2013 | 01:08 PM
wyoming9's Avatar
Red face
it should say Federal or California Emissions Package
Old Dec 9, 2013 | 01:17 PM
Where?
Old Dec 9, 2013 | 01:28 PM
Terrys87's Avatar
There is a white sticker when you lift the hood. It will be underneath and will be on Passenger side, if it is till there. It will say Cali Emiss or Fed Emiss. It will show vac lines and tell information for timing.
Old Dec 9, 2013 | 01:58 PM
I appreciate you commenting, but not the type of advice i was asking for. Im not changing tires/gears. And there is nothing to remove as far as weight goes.
Old Dec 9, 2013 | 02:05 PM
ksti's Avatar
No worries, Iam always learning.
Terry is right, me being from California I just assumed it has o2 sensors.
I thought that all cars/trucks manufactured after a certain year had federal emissions systems, which included o2 sensors.
(I just learned something )
But I must say my rig was manufactured in Japan also, but was probably designated for California as it has emissions system on it including an upstream and downstream o2 sensor on it.
Maybe you can also find out what code your buddy said it's throwing.
Might be able to pin down problem a little easier.
Keep us advised.
Old Dec 9, 2013 | 02:21 PM
SoCal4Running's Avatar
Regardless of what state, country, county, continent or parish you are in if the vehicle does not have the parts on it that it was designed to run efficiently with it will not. Just because of where you are does not mean you can ditch a 02 sensor or the Cat if the computer NEEDS it.
We need to figure out what your vehicle requires.
Old Dec 9, 2013 | 05:12 PM
Bills86e's Avatar
You probly do have the vacuum lines routed wrong, and a packed with carbon Modulator.Pull the cap and clean the Modulator internal filter.
