- 22re swap to 22r
- Best way to remove factory decal stripes
- Overheating 87 4Runner... I'm stumped!
- Exhaust Leaks and Burned Valves
- What Was Your Best Wrecking Yard/Swap Meet Find?
- What is it about the 22RE?
- Switching from 10" wide rims to 8"
- Excessive Crancase Pressure
- exhaust/oil pressure help please
- 22r idleing
- OLD MAN EMU front leaf question....
- 96 tacoma 3.4 5spd 4x4 extra cab trans
- post a pic of your rig! ever have people say good stuff about your 3rd gen runner?
- I saw two Toyota trucks loose their wheels in the same weekend??
- two 4Runners, one project...what to do?
- Rate My Rig Game!!!
- 20r Head 22r Block
- Old Toyota 3VZE Advertisement!
- gonna pick up a 91 turbo mk3 supra
- Getting out broken bolt
- As Long As I'm Down There....
- Help- 2000 4R sat 8 mos. and is now burning oil
- help! 22re exhaust manifold ????'s
- 4runner steering wheel on a rav4
- All Toyota dealers are not created equal!
- shaved doors?
- SAE 30 motor oil instead of manual tranny grease
- water in oil containers?
- Spray lined my LandCruiser
- T100 brake proportioning valve
- Keensert question
- Castrol edge or mobil 1
- Good tip for cleaning the fuel system....
- fried ecu
- Radiator help
- Post your "factory" window stickers!
- Ex. Manifold leak, head and mani are FLAT!
- Timing Belt HELP! Stuck!
- So I Okie Rigged Something Today
- 92 clutch master and 97 slave play together??
- 85 22r missing at 2000rpm
- 22re acting weird
- Fuel Cell Wiring - old or new?
- $0.99 no more cargo pocket squeek mod
- ac install?
- stock yota ring gear vs yukonvs chrono'd ?
- What is more important droop or uptravel
- 22re engine miss
- 23 Gallon Fuel Tank Install
- Recoating/painting Sliders
- snorkle question
- Any tips for attaching hoses to barbs?
- WOW, Toyota coolant is pricey!
- Strawberry Milkshake question
- Is street graphics still around ???
- Oil pan removal - help!
- stuck crankshaft bolt
- 22r cam in 22re?
- VIN Numbers
- shifting problems
- PRETTY?? or PERFORMANCE??
- Tell me about cold start injectors
- auto tranny?
- police spotlight anyone?
- my buddys nervous: 07 Camry Oil Change with loose filter-Damage?
- why are yotas so good off road?
- Duplicolor Bed Armor with Kevlar
- 22re valve tap??
- 22RE idle adjusting
- Crankcase pressure help!
- Tire size/gear ratio/speed/mileage
- Toyota seeks to lower car prices 30% by 2013
- Master Cylinder?
- Who makes this bumper?
- Sky manufacturing leaf springs
- Heater questions
- new jersey inspection
- Post All Flat Beds
- Engine moise after new Head Gasket
- FENDER FLARES...Home made and cheap ($48)
- '91 4Runner AC question
- 89 chevy tranny
- Trailer Arms/Lower control arms
- 2010 Tacoma hitch rust
- Does anyone have spider gears laying around?
- 5VZFE 3.4 Timing Belt Confusion
- I've done it now....rounded off head bolt. Whoops!!
- Rubber Carpet kits?
- 4Runner hood scoops
- Good Shop for gear installs in WA
- Timing Chain
- Sandblasting a chrome grille off of a 1985 Toyota
- How is your rig set up, an do you like it?
- 'high' mileage recommendations
- removing duplicolor bedliner
- horrendous gear noises coming from... middle of truck?
- 22re engine miss
- Toyota's in this month's Offroad magazine
- What brand of lift is this?
- 4.0 tacoma stock exhaust on a 22r.
- Rubber Mats for recovery?
- Washing cloth seats
- Crossmember mount bolt size
- Title/taxes question
- Question about title, taxes etc.
- transmission swap info
- Pulling the Pitman arm.. help?
- Photoshopped paint job - what do you think?
- do i have get alignment done after lift?
- 22r rebuild research
- Brake caliper rebuild, piston questions
- Getting t-case bearings off their shafts
- truck or 4runner?
- Release cylinder
- relationship between charcoal canister and O2 sensor?
- 20/22r hybrid question
- Good form fitting Seat Covers
- Painting my hood, seeking advice
- 1st Generation Toyota 4Runner's.....
- Trail Gear winch mount w/ stock bumper?
- How to tell if bearings are good
- Tundra 5.7 manual trans.
- Trailer Tongue Weight?
- how to find laws about half doors
- buckets for a 92 toyota pickup?.
- Clutch pushrod adjustment does what?
- Grease on new pad material, problem?
- towing 3rd gen 4runner behind RV???
- Problems with insurance related to a camo paint job?
- Failed smog. Any tips or suggestions please?
- Front Sway Bar Removal
- A list of Colorado Specific vendors, shops, and junkyards...
- Mandrel Bent Exhaust?
- Excellent Junk Yard to buy parts from
- Insurance Company HELP with my totaled rig!
- Brake Speed Bleeders anyone used them?
- Rebuilding the T-case
- Toyota synthetic ATF
- How much to Rhino Line?
- 2010 4-runner exhaust tip.
- best "rhino liner" (bed liner) type of product
- Hi-Lift Jack 2" tube mounting system
- 7m-ge Cutting Out
- Good towing article in ORA
- truck feels glued to driveway !!! Brakes jammed?
- Preping for my Cross Country Tow
- Need new rotors. Suggesions?
- Can't remove airbox stud
- 4x4 engine into 2wd truck oil pan clearance?
- Same old stalling problem
- Running rich, bad o2 sensor?
- fuel injectors?
- Now What? Trailer Wiring Issues-blowing fuses
- Toyota Rollovers: Tell your story
- pcv and crank case vent
- 1-3-5 shifting
- Johnny vs. Ballistic Joints
- custom exhaust
- painting frame- rust paint experiences?
- Marvel Mystery Oil Opinions
- What causes radiator hose to collapse?
- Supertech (WalMart) oil & filters
- New truck questions what one to get ?
- Sonoran Steel's NEW website
- Oil pressure
- When did you first realize you needed a Toyota? Post your stories official thread!
- fuel pump problem
- Replacement windshield / aftermarket names ?
- On board air
- Warming up - Waste of gas or preventative maintenance?
- fj40 pickup i want one
- toyota 2J 4cyl diesel
- mechanical fuel pump
- Jerry Can questions
- Battle..87 4runner vs 99 Land Rover
- Annoying noise coming from manifold
- Fender bender! ... Time for Front Stinger?
- Quick drain oil valves - anybody use one?
- cam question
- Looking for a 2wd mileage post.
- can you identify this
- Engine year model?
- Not sure if this is the right thread but I Made a Video!!
- Need help with a LEER camper issue.
- Tie rod rub
- Bent Frame Please Help
- complete 87 22r swap into a 85 toy
- Clinometer plexiglass
- Throttle Body/Intake Manifold Sludge
- Anyone else have a sticky steering wheel?
- Fuel Tank Switch(?) Removal
- Cltuch sheared in two. Idea's?
- my new ride
- Yotatechers! Help me win a 2010 4Runner!
- FJ45 "Toysuzu"
- may be useful info
- need help with wheel bearing preload
- Sandblasting
- Toyota, NASA & Cosmic Rays???
- Grill guard modified to winch mount...
- 93 pickup swap with 85 4runner frame
- Are Chevy leaf springs directional?
- Why couldn't Toyota ever get it right? (rust)
- Truck bed seating?
- San Francisco Bay Are mechanic
- new toyota, new problems, need TPS pigtail
- can you patch up a brake line?
- Fuel Pump Question (Desperate)
- toyota offroad parts magazines
- DUCT TAPE the good the bad and the ugly
- removing 3rd row seats in '06 4runner
- Would like some feedback on a paint job
- PCV Oil Catch Can
- a few spindle bushing questions
- Anyone heard of Viper winches?
- I got a tip for all yall yota techies
- Shift Solenoids
- Junk yard upgrades?
- P0330- knock sensor 2 circuit malfunction/gutless&LOW MPG
- ROYAL PURPLE (opinions)
- Interesting Resistance Readings on Plug Wires
- Tree-hugging
- Will a 00' fit a 92'
- 98 4 runner 6cyl 4x4 brakeing noise
- BajaRack EXP on a 95 PU
- What are the cons to improperly breaking in an engine?
- Switching 22r to 22re
- Timing Belt with marks????
- Interesting oil filter info
- one stop shop for ARB parts
- Thinking of blacking out....Opinions?
- Another Amazing use for WD40!!!
- arb compressor problem
- Clutch...maybe?
- 4 wheel drive issues
- Interior Makeovers, All years
- Interesting new engine design
- got a new to me truck
- New Flowmaster 40 series
- T-case rear output shaft
- Where dose this vac hose go?
- JDM engine replacement
- 3.0 flywheel on a 3.4???
- Fried ground strap?
- Slick 50
- Got spark but wont start
- NWOR selling downey products?
- Freeze Plug???
- Speedo error
- Toyota Recall website
