Price and other info on FJ40 Landcruiser
Old Oct 28, 2013 | 07:45 AM
NorthGuy's Avatar
Hi all,
So I may have the oportunity to get a 1976 FJ40 Landcruiser for about $5000. It is in good shape and has the 6 cylinder engine. I am not real familiar with Landcuisers, what should I watch out for and look for? Any information or advice would be great. Thank you.
Edit: Also, I forgot to mention, could this be a scam (only contact through email)?
Old Oct 28, 2013 | 06:19 PM
rokblok's Avatar
I would investigate just cause I'm crazy that way.
Look for rust or badly bondo'd panels. Rear quarters, floorboards, area above running boards are highly susceptible to rust. The tops rust also, and the rear tailgate/ambulance doors on the bottom.
What area are you in? That has a bit to do with price also.
2F engine, should be 4spd trans, non vacuum shift t-case. Meaning it won't have the pullout for vacuum assist shifting. Match the truck VIN to the frame VIN. Located on the drivers side frame rail at the front of the vehicle. This will tell you if it's a different body from original frame. Check all steering components. There are several tie rod ends, center arm wears out often. Should be front disc on a 76. Rear drums, check wheel cylinders for leaking.
The 2F is basically a tractor motor, in my opinion. Not fast, but heavy as heck and torquey. If you swap the 2F for a Chevy small block, you LIGHTEN the truck 300-400 lbs...
Check for t-case linkage tightness. And driveshafts, slip-joints and u-joints.
If it's in good condition, very little/no rust, and runs, it's worth it. There are restored Cruisers, I mean every nut/bolt, going for $40-60K...
Old Oct 30, 2013 | 07:36 AM
NorthGuy's Avatar
Thanks for all of the information, rokblok. And I'm on the east coast. Definitely a scam though, the guy won't let me see it. Wants to ship it to me.
Old Oct 31, 2013 | 03:53 PM
rokblok's Avatar
Definitely a scam. Walk away...
Sorry you it turned out fake. There are others out there for sure. I bought my current 71 FJ40 for a few hundred bucks in south Alabama. And another one turned up 2days later for $300. I only ended up getting the 1st one and still have it. It's in pieces, as I got it, but the body is good. Just gotta find time...
cruisin69
Early Land Cruisers (Build-Up Section)
34
May 22, 2018 12:25 PM
tobylab
Jan 18, 2016 07:06 PM
digdug40
Aug 28, 2015 02:24 PM
vanion2
Jul 29, 2015 06:17 PM
tobylab
Jul 12, 2015 12:53 PM
