Gear setup...
Old Dec 3, 2013 | 08:47 PM
Neil McCon's Avatar
Gear setup...
So im sick of paying others to have gears changed or setup and now have done my research fairly well and have took many notes. I litterly have made a little notebook with many specs and what not. Even have good and bad gear pattern pictures.. I know the basic concept of setting pinion depth and back lash and preload. Just looking for some good "need to know" info which could be helpful for a first timer. I also have a few questions like where do i get the correct type of spanner wrench for toyota carrier barring screw adjusters. And how exactly can you check the preload on the carrier bearings? I read something about trying to have it around 150-200 ft/pounds? And what do you use to put on the press to press the bearing on without ruining it, also taking it off it the depth isn't correct? I know i might sound somewhat clueless and i am pretty much teaching myself but you gotta learn somehow. I wont be doing this for a bit because I'm lacking tools but im hoping soon. I will be setting up a set Of 5.29s ring and pinion in a toyota 8 inch ring gear diff 4 cylinder front axle. Also where exactly can i find a a cheap inch pound torque wrench thats not a clicking type? Please no rude comments just newbie wanting to learn. Thanks.
Old Dec 4, 2013 | 01:38 AM
91 4Runner's Avatar
gearinstalls.com
Old Dec 4, 2013 | 05:30 AM
rokblok's Avatar
X2. ^^^
Old Dec 20, 2013 | 10:34 AM
jtinco's Avatar
randy's ring and pinion has some good info. I did my first set up with directions from them and that is also where I bought most of the specialty tools that I needed. If you want one stop shopping they should have what you need or check the local parts store/harbor freight for a cheaper version. Plan on spending an entire day getting things set right. I don't have a press at my house so i took an old bearing and used a flapper wheel to open the inside diameter so I could slide it on and off the new pinion gear for setup purposes. When I got the shims figured out I had a shop press on the new bearing which was close enough that I didn't have to have it pressed off over and over to get things right.
Old Jan 9, 2014 | 05:47 PM
daved5150's Avatar
X3 on gearinstalls.com Zuk is a good dude to deal with. I've had questions for him and he's great with email. Very friendly, knowledgeable guy and a member here. Not blaming you for wanting to learn but when it comes to gears, my desire to learn would be trumped by letting my buddy who's got a shop do it with me there so I could get an idea of how to start.
I hear Randy's sells a book on this stuff. Good luck.
P.S. Go with the v6 thirds if you can...bigger stuff inside. Just FYI. Especially with those big meats. Just saying...
Old Jan 9, 2014 | 06:03 PM
JasonYota's Avatar
X4 for ZUK. I'm all about learning how to do things myself but setting up gears isn't where you want to skimp. I could probably set up a set of gears and have nothing go wrong or toast an axle when I need it the most. If your going to regear once get someone good to set it up. If you plan to test different ratios within a few years try it yourself.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
