91 toyota p/u
Old Aug 23, 2014 | 07:50 PM
poundh's Avatar
91 toyota p/u
I have a 22re 91 p/u. I dont know what the timing is on it.
Old Aug 27, 2014 | 08:00 PM
thefishguy77's Avatar
You have to jump the t1&e1 terminals in the diagnostic port next to your fuse block. That will step down your idle. At that point you can put a timing light on it and check/adjust it as needed. If you just got the truck. Most people due a tune up. Just don't use Bosch plugs cap or wires. Ngk if your on a budget and denso or Aisin if you can afford it. Also replace the fuel filter.
Hope this helps
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
nick b
Jul 11, 2015 04:38 AM
