- Problem with new paint job
- Preformance Cam
- Good Machinists in seattle area
- Weight???
- timing chain and rtv
- Hd-sko Sliders
- 2009 4Runner Trail Edition
- Bosch Plat. Plugs +4
- Toyota On-line Parts Catalog
- the rustedyota rebuild
- Turbo Rebuild
- Custom brake and fuel lines.
- Westin Roof Rack
- hook on the engine
- Best place for toyota parts?
- air filters
- Bilstein 5100 vs 5125
- 97 T100 for $3k; deal or no deal?
- Front Bumpers? Are '84/85 mounts and '86-89 the same?
- gsp cv shaft assembly
- how to remove power steering fluid stains
- What are my options for running military tires?
- What Type Of Antifreeze Is Best?
- I NEED HELP WRENCHING!!! In Radford, VA
- Small bumpers suck (proof here)
- What lift and wheels would you run in the NC Mountains?
- Split Coil Spacer Question
- Idling And Misfire Problems
- Gearing and acceleration question
- WTB bucket seat rails 89 T4R.
- Shackle over Frame?
- Stripped stud/bolt holes
- Cleaning oil pickup screen
- Throttle cable pulley sticking
- RPMs fluctuate as brakes pushed
- Heavy Duty Truck Shell Screens?
- head job...still smoking
- locker install - adjuster retainers
- Rant! No Diesels in Canada/U.S.! And no stripped-down 4x4s!
- 3 banger toyota !!
- Power tip-out windows.
- 22RE running rough after rain.
- Add Wheel Speed Sensors to Toyota Ten Bolt
- re-arched springs
- General Maintenance
- Exhaust Gasket Material?
- freeze plug gone bad from rust
- Help! I Need To Pick A Color!
- Best way to remove tie rods
- engine swaps
- **To all Californians**
- 1988 Toyota Dually - Transmission Options
- Antenna help needed..
- Clean Up Oil Stains
- Rear end Vibration 96 t100
- pics of kuhmo tires?
- 85 axle overhaul
- Will wheel spacers affect your alignment???
- 89 22re fuel issues.
- what do you dislike about your rig
- Turbo Diesel Engines?
- i want a OMG!!! taco (all come in)
- Tranny Identification
- TRD customer service BLOWS!
- Jerry Can Measurements
- axle wrap!!!!!!!!!!!
- Fuel injector cleaner ash deposits on spark plugs?
- Water for Gas mod??
- started painting
- what grille is this??????
- Towing a beater in california
- Prado 90 series snorkel on 2nd gen 4Runner?
- bed cover
- Smittybilt customer service
- I need to find these things
- Rampage Grille Guard Would it fit an 87 4Runner?
- dizzy cover
- 31x12.5's on stock 86 runner?
- can you uidentify this transmission?
- maintaining high RPMs with 22R-E
- 22R/22R-E single row t-chain
- lets see some pics!
- tacoma soon to be gone
- what else should i do???
- Mazda 626 Front Right Axle.
- 1986 Toyota Pickup
- Who sells bed mounted spare tire carriers??
- Bike Rack Broke
- biggest tires under...
- Weekend Trip at the Cliffs
- Good shop in Washington, DC area?
- Steering pump / Hydro assist issues!
- Aftermarket Rims - Used
- why is my 22r black soot on my new plugs after one week?
- Factory leaf springs
- weird starting issue
- Affordable torque wrench for pinion preload?
- Door Panel Fix
- Rear drivshaft
- TRD Supercharger Question?
- Brake line blues...
- vin ID
- price of trucks
- Torque Converter Question
- over heating problems
- were to get cheap bucket seats
- heavily oxidized red yota paint
- Toyota sludge settlement
- Brake Drum Removal Help
- sellin my yotas
- Plastic-y coating on shift lever
- Is It Worth It??? Advice Needed.
- mmm.. new hilux
- Common 4runner door problem?
- 1986 22R pickup...vacuum problems...stuck
- ooo pretty flex
- Ethanol Blend Mileage Report
- lift blocks.. this should be fun
- 1st Gen + 3rd Gen = Badd A$$
- People with 350 swap...
- Perhaps the best stock TOYOTA?
- Interesting results!
- converting biodiesel back over to diesel
- Best paint colors...?
- Timing Chain
- 94 yota
- Front Driveshaft
- Suspension & Axle Questions
- Can someone please tell me...
- has my t-case gone bad?
- A/C Condenser Drain TUbe?
- Running board question.
- Where to purchase smittybilt TB80-RH bumper?
- stupid question.
- 3 Strikes in a week
- Sagging back end not what we thought...
- Ac Compressor For Onboard Air
- bars
- Legal, no?
- painting inside of cab and firewall
- Painting RED? Here's some front end options
- 4runner + mosquito net + airmat = super mobile tent!
- BEST 4RUNNER jump action video
- 4Runner seat and center console installed
- Mounting Jspec clino on 4 runner
- surface rust on floor, dynamat/POR15
- Remote mount TPS
- All Toyota Junk Yards
- pickup and tacoma shackles
- CA-40 Fuel additive
- 2005+ Taco Wheel Stud upgrade
- "Hydrogen Booster" Setup
- All Toyota Junk Yard in Missouri
- 35 inch tires
- Stolen cats national attention!
- fuel pump for weber 32/36
- difference between 84 and 85 block
- 98 er what ??
- NWMP and Downey?
- What causes spark plugs to be blown out?
- Tube Doors for 88 4runner
- 8" v-6 third
- 2008 Taco E-Locker Woes
- rattle can soon to come
- How big of a tire fits under the bed?
- might have found new dd
- FJ60 or 1st gen 4Runner?
- Clean cut for dashboard plastic
- Check out the parking lot
- Exhaust manifold
- Steering wheel thread size?
- Engine Cleaner (Topical)
- 82 4x4 for $13,000cdn?
- Shifter Knobs..Lets see em!!
- Got a letter in the mail from a local dealer. Buy back program?!
- 82 yota at prom,
- swap V6 third into SFA
- 2l turbo install questions
- Fix It scratch remover, as seen on TV
- stock cooling system and 100-110 degree heat
- $3...and I get this
- does this sound like a bad fuel pump?
- 261 crawler idle sound
- Polish and Wax Instructions
- exhaust question
- How does a Pinion Gear break?
- Motorcrate.com Rip Off! Do not buy!
- Rig went threw flood. Need help!
- Pull engine with transmission?
- 22r oil filter
- Hard AC question
- Bent the Bud
- Scored a cheap '85 front axle x2
- Would you trust 750 lbs. on this hitch?
- Cleaning out rear axle housing
- Never Heard of CV Break
- ticking sound after rebuild?
- vacuum line @ steering pump
- Can you help me identifying this auto tranny?
- tranny IDing
- Brake and battery light on
- Re-use or get new injectors
- Dada Needs struts
- Single cab or Xtra cab, and my truck dilema
- cost of parts for a nissan pathfinder
- 2nd gen and 3rd gen ?'s
- 1st and 2nd Gen People, Gas Mileage?
- Fair price for spray on bedliners?
- Painting dash
- Locker and spool questions
- LCE or Downey exhaust 2.25" vs 2.5"
- 4runner visor
- Power from Engnbldr RV head and cam?
- lock right install write up
- toyota rust repair
- 2L diesel
- Passed smog by changing oil
- Connecticut bumper height/lift laws.
- Whats going to happen to all the 3.4's
- Anyone with a header that throws O2 code
- Question about simulated beadlock rims
- Intellistick?
- 1984-1988 Toyota 4Runner Incline Altimeter Tiltmeter
- Controlling an A340F/A343F transmission
- 85 Deisel 4x4 1 owner on craigslist!
- I averaged 26 MPG!
- anybody else??
- Faster or Slower Off Road
- Where to find used 22R?
- Toyota Stout Pickup
- Evans Creek, Washington
- My $75 paint job
- 327 v8?
- Paint Question??
- 22re EGR opens at 2700 not 3500 RPM?
- clutch
- OBD-2 scans
- Help on A/C Line clamp
- 5vz Ecu
- lets see some pics of all u guys running 35's
- Sequoia love.... Where is it?
- question about chrome (spraypaint touch up)
- Anybody run 14" swampers?
- off-road capability in new cars
- can u put a std cab on ext cab frame?
- How to check gear ratio on diffs not on truck?
- Anyone ever buy these?
- 22RE running rich???
