Need help. Water temp sensor thread
Old May 11, 2016 | 01:31 PM
localfiremedic's Avatar
Was screwing in my new temp sensor for the gauges on my truggy when this happened?
Anybody know the actual sensor thread that goes into the adapter? I'm guessing it's some kind of NPT.
Old May 11, 2016 | 05:15 PM
wyoming9's Avatar
Red face
If your trying to put that manual temperature probe into that adapter you broke most likely it is not going to work as you found out
It bottomed out before it tightened up
The best way is into the top radiator hose they make metal tubes with the correct size fitting welded in or you can make your own.
I make my own
I would have to double check the correct size of the threads in the manifold
Old May 11, 2016 | 05:59 PM
I make my own
Well it already had a probe in the manifold and I has replacing it. It didn't bottom out from what I can tell. I was barely tightening it at all
nuknuk
Jul 21, 2016 07:04 AM
red247wings
May 13, 2016 04:15 AM
sharrack
11
May 10, 2016 07:09 AM
1994toyotatruck
May 9, 2016 06:59 PM
Turtl3
May 9, 2016 04:04 AM
