Using thread sealant in low temps
Old Feb 12, 2015 | 06:06 AM
83's Avatar
83
I'm hoping to replace the oil pump o-ring on my truck before I head out this spring. This would mean doing it in at most 30-degree temps. Maybe 40 if I'm lucky. But most likely 20s or 30s.
There's that one upper bolt which needs thread sealant. I can't find anywhere if using it in those kind of temps is ok. It only mentions the operating temperatures, and that adjustments can be made for up to I think 24 hours after application.
But will it set up in winter temps? I don't have access to a garage. Well...not one that'll fit my camper.
Anyone know?
Old Feb 12, 2015 | 11:19 PM
wyoming9's Avatar
Red face
I do most of my major work in the winter and never noticed any problems .
I think the cure time may be longer .
To tell the truth I never even thought about the colder temperatures.
Old Feb 13, 2015 | 02:06 AM
Odin's Avatar
I've never seen it done but you could try a low powered heat lamp directed at it.
Old Feb 13, 2015 | 06:06 AM
83's Avatar
83
Ok, thanks. I won't worry about it too much. I'll just pick the warmest day I can to do it.
Anyone have a link of exactly what they use for that bolt? I have stuff I used last time, but after searching around a bit online, I'm questioning whether I used the right stuff.
Getting my head rebuilt this winter, replacing that o ring, and hopefully I'll be good for a while. Considering putting the thinner, 1995 front seal in my front, too...but I don't think that's what's leaking. The oil pump wasn't leaking oil before I did this job, so I'm guessing I just pinched that o ring or something.
If I could just do the oil pan gasket, I'd be leak free...
Old Feb 13, 2015 | 09:07 AM
wyoming9's Avatar
Red face
I pretty much use Permatex Ultra Blue
Old Feb 13, 2015 | 10:19 AM
83's Avatar
83
Huh. So RTV? I was using Permatex Thread Sealant.
Nickyodaman
Jul 27, 2015 12:13 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Poncho0206
Jul 10, 2015 06:21 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
