Cutting through Daystar spacers?
Old Feb 6, 2006 | 10:27 PM
BajaRunner's Avatar
Anyone know if its possible to cut through a daystar spacer?
I want to drop my rear down 1.5" and just want to cut the damn spacer instead of buying new ones. Anyone know if you can just take a hack-saw and saw through it?
Old Feb 7, 2006 | 02:29 PM
Flamedx4's Avatar
I seriously doubt it.
But if you take them to a machinist he can cut them down properly. (on a lathe)
Old Feb 7, 2006 | 04:42 PM
BajaRunner's Avatar
So this urathane stuff is pretty solid, eh?
Old Feb 8, 2006 | 09:42 AM
Flamedx4's Avatar
I assume these are polyeurethane? It's not exactly the 'solid' that's the problem (although the stuff is high density - it IS designed to be durable after all) it's the elasticity that's problem. A saw will grab it instead of wanting to cut smoothly through it. Plus there is the issue of how to hold it steady without flex (to get a straight cut) and without crush (thus gripping the saw) and how to cut straight and true in the first place. Poly is normally machined, it's quite easy to cut that way and shouldn't cost much to have it done.
Old Feb 8, 2006 | 10:27 AM
snap-on's Avatar
find a friend with a bandsaw. should cut through it like a hot knife through butter (assumeing you have the right blade)
Old Feb 8, 2006 | 01:22 PM
6lug's Avatar
Id say that if you used a bandsaw with a blade with around 32 teeth/inch, (or lots of little teeth) you'll be ok. Im plannin on doing this when I get my OME H/D coils b/c Im afraid that after I load up the truck, it will be a little sagged, so i was gonna cut my spacers down to about an inch...let us know how it goes.
Old Feb 8, 2006 | 02:52 PM
BajaRunner's Avatar
Well Im going to see if anyone wants to buy them first. If not then I'll go make some phone calls and see if anyone will do it for me.
Old Feb 8, 2006 | 03:17 PM
YeloSub7's Avatar
I held mine with a table top vice and then cut it with a skill saw. The hacksaw works too, but just takes longer...
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
