Help with cold starting
Old Dec 19, 2005 | 06:47 AM
Innocent Fool's Avatar
Hey Guys
Haven't been here for a while but I've got a problem with my truck and I was hoping someone could help.
I've got a 91 2wd PU with a 22r 5spd Fuel Injection.
The problem is it just doesn't want to start when it's cold! This is my first winter with this truck.
I NEVER plugged in my 88 2wd PU with a 22r 5spd Carborated truck and it had NO problems starting in -40 (and it was down there a couple of weeks at a time). Had no problems at all... Talk about a great truck!
But my 91 just doesn't want to fire when it gets to about 0. WTF??? The only real difference I can see is FI vs Carb
Does anyone have any hints on what to look for? Cranking isn't a problem but it seems like there's a problem with the electronics/sensors or something. I don't "think" it's flooding, it just doesn't want to fire
I can't plug it in because I've got nowhere to plug it
If anyone has any advice it would be GREATLY appreciated
Thanks in advance!
Old Dec 19, 2005 | 02:57 PM
84sr5yoty's Avatar
Either it's the cold start injector or the cold start injector time switch. 99% of the time it's the cold injector time switch.
For testing of the cold start injector time switch, remove the connector and measure the resistance between the two terminals. The cold start injector time switch is located right beneath the bvsv valve. The sensor to the right of it is the water thermo sensor (also known as the coolant temperature sensor). My manual is for an 84 so yours may vary. But if you're curious mine indicates 20-40 ohms below 86 degrees F and 40-60 ohms above 104 degrees F. From the lower prong to ground should be 20-80 ohms.
For testing of the cold start injector, remove the connector and measure the resistance between the two terminals. My manual indicates 2-4 ohms. However, the injector could ohm out correctly yet be plugged.
Old Dec 20, 2005 | 09:45 AM
Thanks a TON!
That would definatly be the last thing I would have checked
I'll check it out tonight!
Thanks again!
Old Dec 21, 2005 | 08:48 AM
Dude I owe you a beer!
Changed the cold start injector time thing and all was right in the world
Thanks again
Cheers!
Old Dec 23, 2005 | 05:28 PM
84sr5yoty's Avatar
Glad it worked out
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
Doug4320
Mar 24, 2018 10:11 PM
Jonny246
Jul 12, 2015 04:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
