View Poll Results: Do you gap you plugs?
Gap Them!
71.94%
Straight outta the box!
28.06%
Voters: 139. You may not vote on this poll
Do you gap your plugs?
Old May 10, 2005 | 10:20 AM
Blair's Avatar
Do you gap your sparkplugs?
Or straight outta the box...
Old May 10, 2005 | 11:02 AM
seaflea's Avatar
I gap them. I need every bit of help I can get out of this 22-re
Old May 10, 2005 | 11:16 AM
calg3's Avatar
Always!
Old May 10, 2005 | 11:52 AM
Lone4runner's Avatar
outta the box dont know how i would gap the platinums 4's
Old May 10, 2005 | 12:01 PM
Blair's Avatar
Pretty sure you can't gap those.
Old May 10, 2005 | 02:33 PM
Glenn's Avatar
NGK come out of the box already gapped for my application. But some other brands have to be gapped.
Old May 10, 2005 | 02:41 PM
dwh91102's Avatar
I always check my plugs even if there already set just to be sure, so I voted gap em
Old May 10, 2005 | 02:44 PM
Wildcat_4R's Avatar
I check'em as well. I had problems with the denso plugs from Toyota that were "pregapped". Always check them now.
Old May 10, 2005 | 03:03 PM
what about the platinum 2's which are the replacement for my stock spark plugs. can you gap those?
Old May 10, 2005 | 04:39 PM
Blair's Avatar
I've always 'heard' that standard plugs can be gapped, but don't need to be. and that platinum plugs (any kind) should NOT be gapped. That is the reason for this pole. I'd like to see what others are doing. Most often I will check the gap with a feeler gauge and only once have I ever had to actually adjust to spec. But I think I dropped that one, trying to get it in the darned "5" hole, which ALWAYS gives me a hard time. In fact, I think I have a used plug sitting on that little shelf under the cylinder bank right now which I dropped on extraction.
Old May 10, 2005 | 06:24 PM
kyle_22r's Avatar
easy, throw them in the garbage, buy a set of NGKs, and gap them
i gap mine to .040, i'm running an accel super stock coil. makes it easier to start the engine.
Old May 11, 2005 | 04:37 AM
hillbilly's Avatar
Ditto...
Old May 13, 2005 | 11:44 AM
boogyman's Avatar
i used to check em and found that they've been fine every time.. so i just throw em in now. haven't had a problem yet
Old May 15, 2005 | 05:24 PM
CynicX's Avatar
i buy them gapped and check em before i install them....
Old May 15, 2005 | 10:00 PM
superjoe83's Avatar
i gap the plugs that go in the taco, but everything else (4runner, lawnmower, quad) i could really care less
Old May 17, 2005 | 04:07 AM
Ganoid's Avatar
I gap mine to .065 every time.
Old May 17, 2005 | 07:40 AM
Blair's Avatar
Just curious, Ganoid, what does the over spec do for you?
Old May 17, 2005 | 01:28 PM
Silver_Truck's Avatar
gap em unless they come out of the box w/ the right gap
Old May 17, 2005 | 11:27 PM
GGoldhag's Avatar
I am getting the Iridium Denso IK16's do they need to be gapped?
Old May 18, 2005 | 07:48 AM
Steveh29's Avatar
I always check the gap. Densos and NGK's are usually OK out of the box but occasionally one needs adjustment. When working on my old big block Ford, they always need gapping out of the box.
