View Poll Results: Do you gap you plugs?
Gap Them!
71.94%
Straight outta the box!
28.06%
Voters: 139. You may not vote on this poll
Do you gap your plugs?
Old Jun 14, 2005 | 10:08 AM
MTL_4runner's Avatar
I give em a visual inspection (for any physical damage) on the Densos and NGK's.
......otherwise I install them straight out of the box.
Old Jun 16, 2005 | 09:14 AM
deathrunner's Avatar
does it really make a difference? i gap em too
Old Jun 17, 2005 | 07:38 PM
dwa's Avatar
dwa
NGK says don't
I had the same question and e-mailed NGK. This was the response:
"When they talk about gap they are referring to single ground spark plugs.
The gap for the dual ground is measured between the insulator and the bottom
of the ground electrode. This spark plug is designed for anti fouling. If
you adjust the gap on these spark plugs the spark plug won't perform
properly. Again dual ground electrode spark plugs don't require gapping."
I asked for clarification re the measure being between the insulator and the bottom of the ground electrode and this is the response I got:
"The gap is read between the bottom of the bent part of the ground electrode and the insulator to the center electrode. These spark plugs are designed for anti fouling. When the insulation resistance is lowered by carbon deposits it fires across the insulator and breaks the deposit off. You can't adjust the gap on dual ground spark plugs. When they refer to gap, they are referring to a single ground electrode spark plug. This doesn't apply to a vehicle with dual ground spark plugs installed."
For what it is worth.
Old Jun 18, 2005 | 08:55 AM
so that leads me to assume that you don't need to adjust the plugs with 4 electrodes.....good to know.
Old Nov 22, 2005 | 04:35 AM
  #25
habanero's Avatar
I'd still check the duals and exchange if the gap's wrong. It may be less likely that these would get bent but too many people handle plugs before we buy them and many don't think a thing about sticking them back on the shelf after dropping them. The singles I always check and adjust if need be. For a few extra seconds of time to insure I don't have to pull a plug it's not worth not doing it.
Old Nov 23, 2005 | 04:00 AM
  #26
pat161's Avatar
I always check them, why wouldn't you?
Old Nov 23, 2005 | 02:28 PM
  #27
spyne's Avatar
I've gotta gap them. Who knows how many times they've been dropped during shipment, banged around in the parts room, etc.
Old Nov 26, 2005 | 12:35 PM
  #28
kyle_22r's Avatar
platinum 4 plugs are a waste of money IMHO. most guys like NGK or denso plugs for toyota engines, though i've never had problems with autolites either(i run them in my trail truck)
Old Nov 26, 2005 | 12:41 PM
  #29
mach4's Avatar
I use NGKs and Densos and always gap them.
FSM and owner's manual says to gap em.
There was a post a while back where someone had changed out the spark plugs and started getting knocking.
He pulled all the plugs out and one of them looked like it was misgapped.
The spark plug was replaced and knocking went away.
Now, there could have been something wrong with the inside of the plug or it could have been damaged in some fashion, but why take the chance when gapping is a simple procedure.
Old Dec 5, 2005 | 09:38 PM
  #30
getitdone's Avatar
Originally Posted by kyle_22r
easy, throw them in the garbage, buy a set of NGKs, and gap them
Yep, he's right.
Old Feb 24, 2006 | 01:28 PM
  #31
Tacoclimber's Avatar
I always check mine...
Old Feb 24, 2006 | 02:18 PM
  #32
V_Runner's Avatar
Banned for stupidity
NGK's pregaped or ungaped work fine...BUT YOU SHOULD ALWAYS GAP THEM...gapping them makes them fire hotter or colder and depending on the enigne they should be gapped correctly for BEST preformance...
Old Mar 5, 2006 | 07:11 PM
  #33
WV Jay's Avatar
Originally Posted by dwh91102
I always check my plugs even if there already set just to be sure, so I voted gap em
same here
Old Mar 5, 2006 | 07:42 PM
  #34
srpage's Avatar
I always check em first and generally the gap is correct.
It seems foolish not to at least check the gap before you install em.
Blamalam
Mar 12, 2022 07:34 AM
young buck
18
Aug 27, 2018 02:40 PM
256mbaker
Jul 31, 2015 06:45 PM
ddg71
Jul 24, 2015 01:24 PM
cars-guy
Jul 11, 2015 07:51 PM
