Gear Oil vs. "Hypoid" Gear Oil
Old Dec 18, 2003 | 03:29 AM
4RunnerFever's Avatar
I'm prepping and studying to do the 60K tune up myself (save the timing belt) and I see that Toyota calls for gear oil in some situation and "hypoid" gear oil in others.
Can anyone clue me in to the difference? I'm planning on switching to Amsoil synthetic and I don't see anything from Amsoil that says 'hypoid.'
My guess is that the synthetics will take care of any of the differential and/or transfer case fluid requirments.
Thanks Folks
Old Dec 18, 2003 | 04:48 AM
4RUNR's Avatar
Guest
Hypoid oil is for those slanted gears thingies that create more pressure than normal gears, hence needing better gear oil.
Just google it for an indepth.
Old Oct 14, 2007 | 01:24 PM
4Crawler's Avatar
Hypoid gear oil is generally GL-5, for use in the differentials:
- http://www.4crawler.com/4x4/index.sh...ntheticGearOil
You can usually use GL-5 in all the gear boxes, but GL-4 will work better in the transmission. It is not so much the GL-5 is "better" than GL-4 oil, they are just designed for different applications.
Old Oct 14, 2007 | 03:02 PM
86tuning's Avatar
Yup.
GL5 or 6 (hypoid) gear oils in the front and rear differentials.
GL4 or GL5/6 for the manual trans and transfer case.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
msane99
Jul 11, 2015 08:08 PM
