Mixing tire brands, is it ok?
Old Oct 19, 2003 | 07:55 AM
4runner4life's Avatar
I recently had a blowout of my right rear tire. I currently have Goodyear Wrangler AT/S 265/75/16. I want to make the transition to the Bridgestone Dueler A/T cause I can get a better deal through Costco than any local tire shop. The Goodyears are still in excellent condition and won't need to be replaced for quite sometime. Should I go Goodyear until I'm ready to change all 4 or is it ok to throw one Dueler into the mix. I'm a little confused at which direction to take. Thanks for your input.
Old Oct 19, 2003 | 08:46 AM
Victor's Avatar
You didn't get road hazard? Take them to a Goodyear dealer and see what kind of deal they can give you. I'm in the no vote camp when it comes to mixing brands - different handling in rain and cornering.
Old Oct 19, 2003 | 06:55 PM
mtnfreak's Avatar
Once your tires have more than 5-10K miles on them (how many miles depends on how well the tires are wearing), then they should be replaced in pairs. Running tires of a different circumferance (even slight) can lead to handling issues in the front and driveline & tire wear in the rear. Switching brands for just one tire is a no-no for the same reason. You'd think that everybody's 265/75/15's would have the same measurements until you actually go into a tire shop with a tape measure. Also, I wouldn't go with a different tread pattern on only one wheel - handling in the rain, snow, dirt, etc. can get funky when one tire behaves differently from the rest.
Oh, and for $5 or $10 per tire, a road-hazzard warranty is well worth it.
Old Oct 19, 2003 | 07:45 PM
its2slo's Avatar
when i bought my truck six years ago it had 3 different tires: a Le Mans AT (huge 31x10.50r15), a goodyear rts (265/75/15), and two dean tire co. trailcat lt's (wimpy 31x10.50r15). the mis-match pair was on the front and it still handled fine.
then one of the factory alloys broke (my bad) so i bought four new ones and put michelin ltx's on.
i gave the "crap" to my dad, he found a single wheel on ebay and is running the set to this day on his 89 toy pickup with no problems.
Old Oct 20, 2003 | 09:03 AM
I bought the truck in January and I'm waiting for the prev. owner to get back to me on the purchase details. I didn't think it would be a good idea but this is my first truck and I'm still wet behind the ears. Thanks for the responses, it really helped.
Old Oct 20, 2003 | 09:55 AM
PistonSlap's Avatar
It is not a good idea, but in reality, you will be just fine. While it is true that it may increase wear, but it is nothing to be concerned with. You can probably get 500,000 miles out of a toyota axle. So what if you shorten the life a few thousand miles. I wouldn't suggest mixing tires, but there is no need for concern. Do what works best for you.
Old Oct 20, 2003 | 10:44 AM
SLC Punk's Avatar
I think you should be ok. If you were going to put an M/T on there, it would be another story.
I always replace mine in 4's if I am changing the tire brand. When I blew out a tire on my Celica, my other three were still new. But since the previous owner put the wrong size on, I bought 4 tires. Discount tire bought back my old tires (gave me $40 credit). It isn't much but it was a weird size. Check and see if they will buy the other 3.
Old Jan 24, 2006 | 07:25 AM
Joyota's Avatar
Wow... an old thread revived
My brother-in-law has an 88 4Runner with BFG 32x10.5 A/T's on the front and BFG 32x10.5 M/T's on the rear. I'd like to get these tires from him. Will they be ok to run like that?
Old Jan 24, 2006 | 07:42 AM
Tacoclimber's Avatar
Well, if you plan on keeping them for any length of time, I would say no, since you'll be rotating them eventually... but since it appears that you're in the market for a couple more, you'll probably be OK.... for a little while...
Old Jan 24, 2006 | 08:03 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
If you MUST mix brands, then it's best to maintain the same style tire on each axle. Although dry handling differences aren't as notable, wet/slick conditions with different tires on the same axle may cause detrimental handling.
Old Jan 24, 2006 | 09:26 AM
MTL_4runner's Avatar
Ditto, stick to having the same tires on both front wheels and both rear wheels but the tires can be different brands front to back. I would never recommend different sizes on any vehicle unless the diameter of the tires were the same (ie P265/70R16 and P285/65R16 would be the same diameter but different sizes and would be fine to run with each other).
Old Jan 24, 2006 | 10:12 AM
snap-on's Avatar
Ive got diffrent flavors on both of mine (now)
mine are in pairs, front and rear. Ive had no problems in the year ive owned the 4r other than when i got it only 1 tire had wheel weights on it, and when i had them ballanced (after the new shocks went on) one of the no weight wheels picked up like almost and ounce of weight.
Old Jan 24, 2006 | 10:44 AM
Joyota's Avatar
First... as a side note, this thread is old. I just thought my question might be best placed here, since it falls along somewhat the same lines as the original question.
The tires I'm getting are all the same size. I'll have All-Terrains on the front and Mud-Terrains on the rear. Same style on each axle. So I should be ok then, right? Btw, I plan on getting new tires before I ever have to rotate these.
Old Jan 24, 2006 | 10:56 AM
Rick F.'s Avatar
.... So I should be ok then, right? ....
Correct. Right. Yes.
Old Jan 24, 2006 | 12:25 PM
jeremys73's Avatar
I use to run different one brand on the front axle and another brand on the back and never had any problems at all. I think as long as you don't have a spool or locker in back and don't drive in 4HI on the pavement you should be fine.
Old Jan 24, 2006 | 04:02 PM
Joyota's Avatar
Cool guys. Thanks for the help!
BushPig
Oct 29, 2022 06:26 AM
young buck
18
Aug 27, 2018 02:40 PM
Zpd426
Jan 2, 2016 01:15 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
