? Valve Train Noise
Old Jan 2, 2006 | 03:17 PM
? Valve Train Noise
Got a noise that showed up recently (145K mileage). It sounds like "dieseling" or rattling a box of nuts. It only happens with acceleration or throttle demand.
I've changed the spark plugs and they look pretty good (I can snap a pic if needed) and cleaned the intake.
Is this valve noise suggesting adjustment is needed (never been done)? Or is it crummy gas? Or What???
Thanks in Advance
Andrew
Old Jan 2, 2006 | 04:30 PM
tc's Avatar
tc
Check the timing first.
Did you get the same temperature range plugs?
Old Jan 2, 2006 | 05:15 PM
Same plugs as previous. I use the NGK stock plugs. The noise was occuring even before the plug change.
Andrew
Old Jan 2, 2006 | 05:54 PM
marko3xl3's Avatar
Is it kind of like a ticking noise, something like this:
http://www.marko3xl3.com/sounds/ (click on either one)
If so, that's normal for high milage 3.4L, it just comes. It's usually more pronouced once the truck warms up. Most people say it's the valves that need to be adjusted, but some have tried and it didn't cure the problem. For now, I wouldn't worry about it unless it becomes more noisy, at which point it's probably time for a valve job. If it's the fuel injectors, they'll just do that 'cuz they are old as fart, they still run perfectly fine tho. If you want to confirm where it's coming from, get a mechanical stethoscope or use the poor mans type (screwdriver butt to ear, tip to whatever) to check.
JNapolitano
Nov 14, 2019 07:46 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
calderp
Jul 27, 2015 09:58 AM
razorman8669
Jul 12, 2015 12:13 PM
