Pull the head?
Old Sep 27, 2011 | 06:04 AM
mommucked's Avatar
Pull the head?
I need to replace the timing chain in an 82 22r, will be adding the double row chain.Ive done this before many years ago on an 84 and i didnt remove the head, I pulled the front cover and removed the piece of head gasket and replaced it w a homeade gasket. It might have worked better but my dad assisted and tightened the bolt under the camgear too tight and cracked the cover under the bolt hole. i jbwelded it but it still leaked. Has anyone else done the swap this way? if money allows I will pull the head and change it w a reworked spare but money is tight now.
Old Sep 27, 2011 | 06:44 AM
snobdds's Avatar
Pull the head...why half as* something. Put a new OEM head gasket and clean stuff up. You will not leak at the joint bewteen the head and the cover if you pull the head.
Old Oct 19, 2011 | 09:01 AM
bg's Avatar
bg
you can sometimes avoid pulling the head if you remove the oil pan so you can drop the cover down without excessive damage to the gasket and reinstall the cover without mashing the gasket. its not ideal but i've cut the gasket and used ultra gray (rtv) with reasonable result but it will always leak alittle.
Old Oct 19, 2011 | 06:46 PM
Grego92's Avatar
Yeah, pull the head! I asked that question not too long ago doing the same thing....just don't get carried away like I did.
This is where I'm at now
Old Oct 20, 2011 | 06:08 PM
mommucked's Avatar
Yea, thats what I'm afraid of ! As long as the heads off, why not redo the bottom end?........(funds). I made a gasket out of gasket material last time I changed one, I think the oil leaked from the cracked cover I tried to patch after it was installed. This is another motor w/o a cracked cover. Im gonna check compression and go for it if comp. is OK.
Old Oct 20, 2011 | 06:32 PM
87 Deathtrap's Avatar
I've done this to reseal a leaking front cover since I needed to do an oil pan gasket anyway. Might have just been lucky, but everything sealed up fine and didn't leak again.
bigjstang
Jun 2, 2025 03:56 PM
cars-guy
Aug 16, 2020 06:59 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
