Removing the air vents?
Old Dec 1, 2011 | 02:47 PM
Compass Creek's Avatar
Anyone know how to remove the air vents in a 87 pickup without breaking something or removing th dash?
Old Dec 1, 2011 | 03:14 PM
85TurboRunner's Avatar
You pretty much have to pull the dash pad or the part over the gauge cluster depending on which vent you want to remove. Its very easy though.
Old Dec 1, 2011 | 03:59 PM
aviator's Avatar
Not hard to do the dash comes apart very easily... and yes you have to do that to get the vents off... you start with the lower dash/glove box/the lower radio stack/the radio surround/ the binnacle (gauge cover)/the gauges/then finally the upper dash with the vents... takes a lot less time then it sounds... first time might take you up to 2 hrs but after that it will go quickly... (I can strip mine down now in just over 30 mins but I've done it a lot lol) just take you time the first time you try or you may break some thing and these parts are getting harder to find... forgot to tell you to remove the tabs on the heater controls first...
hope this helps
Doug4320
Mar 24, 2018 10:11 PM
dumpster84
Apr 30, 2016 06:03 AM
TJWilly
Jul 31, 2015 02:05 PM
Toyvana
Jul 29, 2015 10:47 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
