will a 1987 4runner body mount easily to a 1981 pickup?
Old Aug 9, 2011 | 10:36 PM
Toyota745's Avatar
i have access to a cheap 1981 reg. cab, shortbox pickup, 4wd of course ;], and i was wondering if it was easy to put my 1987 4runner body on to it to take advantage of the solid axles, and a good running driveline
thanks
Old Aug 10, 2011 | 04:36 AM
waskillywabbit's Avatar
I bet no.
:wabbit2:
Old Aug 10, 2011 | 04:42 AM
xxxtreme22r's Avatar
probably not. Maybe the bed though. ????? Oh wait he said 4runner body not pickup body, then nope not without some and
I would be just as "easy" to swap the entire suspension over to the 4runner.
Old Aug 10, 2011 | 06:40 AM
tj884Rdlx's Avatar
the FSMs have a diagram with measurements of the frames and body measurements. this may be the quickest and easiest way for you to compare the two completely different chassis designations.
if you want to see for yourself exactly how different the mounts are, download the FSMs (ncttora is a good source) and compare. You may find its only body mounts that need to be cut and rewelded to the frame, then the use of some 1" body block adapters, which you may need to custom craft.
i suspect that the diagrams will illustrate the trucks are very different, with regard to alignments of frame mounted mechanicals that penetrate the body, i.e. shifters, pedals, heater/ac parts, as well as frame mounted mechanicals which conform to the body i.e. exhaust, fuel tank mechanicals.
but anything can be done with enough time and motivation, if you really want to combine a good frame with a good body.
Old Aug 10, 2011 | 06:46 AM
the fsm on ttorra for the first gen isn't gonna cover the 81. It's an 85 manual, completely different body. Which would practically be the same body mounts as the 87 4runner since the 87 and 85 4runners were the same body.
Old Aug 10, 2011 | 07:15 AM
tj884Rdlx's Avatar
i don't know what's in that huge zip file on ttora, but it says "79-85". it's all '85? i can't download it here.
toyotareference dot com lists the '81 as an RN38 frame. the '87 body is on an RN61 frame.
so that's what you'd need to find diagrams of to compare specs.
Old Aug 10, 2011 | 07:17 AM
it says 79-85 but it's an 85 specific manual. Everything in that manual is related to the late 22r block as well, nothing in there about the early block. IIRC.
Old Aug 10, 2011 | 07:52 AM
bob200587's Avatar
It was my understanding that the solid axle trucks and 4runners were a few inches narrower. I figure that might make things a little complicated
Old Aug 11, 2011 | 04:26 PM
wyoming9's Avatar
Smile
The real question is how does the OP define easy???
One persons easy is the next persons impossible
arlindsay1992
Jan 23, 2024 01:34 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
91toybeater
Dec 27, 2015 07:46 PM
