Dirty Throttle Body
Old May 18, 2011 | 07:03 AM
ccford's Avatar
Dirty Throttle Body
I have 97 tacoma 2wd with a 2.4L 4 cylinder.
When I bought the truck (111K miles), I checked the throttle body to see if it needed to be cleaned. I have never seen a throttle body so dirty. I had to scrape out the gunk with a razor blade. I could not get a gasket that weekend and cleaned it with it still on the truck.
It has been about 27K miles since then. I pulled off the throttle body last weekend to check it and clean it. Was not nearly as dirty, but there was a pretty good build up on the back side of the butterfly.
The truck does not make the power that I think it could, and the gas mileage is not great either. I average about 16-17 mpg.
When i pulled the TB noticed that the port leading to the egr valve is very dirty. Could not get it clean. There is still a lot of gunk. I have been thinking that the egr might be stuck open.
Just wondering if anyone has had this problem and knows what might be causing this. I live in Alabama and don't have emission testing. So disabling is a possibility.
Also wondering if I will likely get improvements in my engine performance if I replace my O2 sensors.
Thanks for reading.
Blamalam
Mar 12, 2022 07:34 AM
Blamalam
Aug 16, 2015 12:29 PM
mtc1105
Aug 4, 2015 08:06 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
