View Full Version : The Fab Shop
Pages :
1]
- 2nd gen tacoma 4wd conversion
- A sound question
- broken rear trailing arm mount
- Motor Rewind Questions
- Dana 80 to toyota adapter (how to)
- 1994 pickup bedsides on 2003 bed
- Land Cruiser 80’s series mechanic needed.
- Is adding an undertray to block mud/rust feasible?
- Wheel suspension
- Couldn't find a skid plate for my 87 4 runner, so I built one
- 93 Toyota pickup dlx 4x4 long travel rear info
- Auxillary Fuse Block Bracket for 1st Gen 4Runner
- A pillar rust/ patch panels
- Custom cabs?
- Front bumper mounts
- El Dorado caliper retrofit on rear disc conversion
- Anything Fabricating Ask your questions!
- Custom skid plate
- 1986 Toyota pickup exo cage
- What size for my second JD2 die
- Home made bumper on a 97 yota
- 2nd Gen 4runner Front Bumper Build w/ CAD Files
- 1995 Tacoma frame
- AllPro D60 Toyota Hybrid Questions
- Looking For Mounts
- Botched 63 Chevy Swap??
- 1st Gen 4runner New Remanufactured Tailgate Panel
- Rusted through frame
- 2nd Gen 4Runner 2.50" FlowFX CAT-Back
- 1st Gen Tacoma Front Bumper on Pickup (92)
- Rear bumper build, 1st Gen
- 1983 yotam brush guard
- Ruf and Chevy 63s, need opinions
- 1984-1988 Reproduction dash crash pad
- Budget But Effective Rear Disk Brake Upgrade
- Fire extinguisher mount
- Air cleaner nut
- Custom shackles
- Cutting the back off the fiance's 4Runner
- Correct Glue for Gen 3 4Runner Dash Pad
- 2nd Gen rear swingarm bumper
- 83 1st gen chassis swap into 47 Willys?!?!
- Front drive shaft clearance opinion
- bobbed bed rear lift help
- 87’ Starcraft Pop-up build
- Bumper Swap?
- 4runner floor pans in a pickup extracab?
- v8 header info
- 3.0 - 22re swap. Motor mounts. Who'se done them?
- 4 link design check?
- Best way to fix this the right way. Advice please
- Grease For Sanden OBA Compressor
- Custom Yota Hauler
- toyota tacoma exhaust
- Custom Gas tank help...
- 2" round stock bumpers
- cab top chop swap with pop pop
- Roll cage?
- 81 Flatbed Build
- Crawler hauler rehab - Fixing a rusty car trailer
- 2nd Gen PU Hood Scoop
- What 3rd gen bumpers can go on a 2nd gen 4runner ?
- 1992 22re flat bed buildggle
- 2nd ac compressor as on board air?
- Help id bumper
- Power rear window in my 1987 yota
- 87 toyota rear end swap. Now I have axle wrap!
- Custom bumper
- Factory bed/tube bed hybrid question
- Rocker panel sliders? Need some creative input.
- 94 grille?
- Solid axle hub bodys on a Ifs truck, Narrower track width?
- 94' yota
- 40" light bar + 93 pickup, how?
- 3 Link build with questions
- 94 pickup 3L 4x4 XCab Exhaust advice
- 90 truck fender cut and fender flare question.
- W50 to W56 Transmission Swap
- 84 front end reconstruction
- Thoughts on rock sliders kick-out, mounting options?
- any one know? tooth count on ps input shaft
- 63" chevy leafs in rear
- 1990 pickup grill conversion
- Seat swaps
- 1999 tacoma traction bars
- Crossmember for 2nd gen, Auto 4Runner
- Bed cover lift assist
- 4.3l exhaust swap help
- rag joint delete help.
- Let's See Your Hunting Setups
- Redeth's Overland Trailer Build
- Dream Bumper Build
- Divorced T-case
- Safari Rack Build, 89 4Runner
- Steel bumpers!!
- Replicating NWOR 1st Gen HD Roof Rack
- 2wd rear leafs help 1985
- 83 Toyota - Push Pull Steering help
- Custom Built Heavy Duty Bumpers?
- 84 frame swap
- Light bar mounts
- Rear bumper?
- Frame work 93 pickup
- 1st Gen Bumper
- Right build for me
- Roof rack
- Custom snorkel
- radiator, what to use as cussion
- 86 vs 89 bed alignment
- 82 frame options?
- ifs diff questions
- Swing Out Modular Rear Cargo Bumper for 1st gen 4Runner
- Suspended pickup storage (?)
- Swaybar disconnects
- Front tubular upper & lower arms
- Heavy duty 92 pickup plate winch bumper
- 3rd Gen LED Light Bar channel brackets
- BruceTS rear bumper
- First Gen 4runner rear plate bumper
- new exhaust 94 22re
- Building wheel wells
- Fender Repair
- Half doors
- 82 frame repair
- trail gear bumper measurements
- Lets see them Flat beds
- 99' 3rd Gen T4R front frame horn question
- 2nd Gen 4Runner Ditch light brackets
- Exhaust
- Harness bars/mounts!
- crank bolt won't come off with impact
- Heated leater seats junkyard swap
- Building headache rack for 92 pickup
- supacharga! dynamic tensioner bracket
- Light bar mounts
- 2.0 Bumpstop Mounting (front)????
- 3gen hood
- Favorite CAD program?
- Square tube rock sliders
- Bumper mounting
- First gen bumper mounting
- Trail gear, 4wu, ruff stuff, barnes 3/4 link front/rear
- Custom t100 skid plate
- my 1988 flatbed
- 88 4runner front plate bumper
- 1979 power steering
- Redneck Truck bed Ideas
- custom first gen 4runner all metal high clearance fenders
- Kids Wagon Rebuild (pic heavy)
- fj80 rod ends N stock tie rod
- 4 link suspension for a rookie
- Anyone build a safari style roof rack?
- broken front spindle-name that year challenge
- Need input on creating my own trailer hitch
- Disc Brake Mounts
- Need advice ! Broken upper control mount !
- Tube fenders for my Toy!!!
- Custom truck bed toolbox
- 1st gen runner 4 link
- 1st gen runner 4 link questions
- 4 link build questions
- 4 link questions
- BJ Spacer Install - Wham bam thank you Mam!
- '98 Jeep XJ bumper on an '84 Yota PU?
- Need help on hydraulic steering
- Welding my gears?
- roof rack, check
- Custom Built 3VZE Upper Intake
- 1st gen bumpers
- Supercharger & Bypass valve?
- Dual case crossmember
- IFS - Control Arm Failure, What The Heck
- flatbed question
- T100
- T100 Bumper
- removable doors
- 2nd gen 4runner to 4 door flatbed pickup
- my flat bed
- need a quick measurement or two
- custom fender flares/ bumper
- Traction bars and Articulation.
- '94 runner custom bumpers/tire carrier
- Does anyone make custom quick disconnect sway bar end links
- Chop top 90 4runner
- Custom long travel. CV axles?
- Centering a landcruiser rear axle build
- fix or replace rear axel?
- Advice on winch plate
- My first attempt at building a flatbed
- 92 22re to carb???????
- Auto blade lift on band saw
- rocker panel repair and bedliner
- Beware Miller Maxstar Syndrome !!!
- how can i bend a frame?
- tacoma long travel
- CNC Scanner upgrade for my mill
- Tacoma Rear axle housing!! Rusted
- Rusty '87 4 Runner rear quarter panel removal and fab
- 86' 4runner: Lockable Storage/Console
- 86 4runner front and rear tube bumper
- Tow Bar Brackets on Front Axle
- Light bar mount question!
- 1 Ton Chevy axle swap ?
- Rear shock mounts
- 80 Amp Welder
- Exo-cage planning help needed
- Andersej: 2nd Gen 4runner Slider Build
- Rock slider build
- IFS front skid plate build
- IFS in a 83
- My new tailgate
- spare in the front?
- roof rack pickup build, post your pics and ideas
- Nick's '88 4Runner Rear Bumper Build
- Rear Shock Mount
- 2wd pu spindles fit on 2wd t100
- Redeth's 89 4Runner custom front plate bumper fab.
- Clutch line flare sizing/fitting???
- Work flatbed build
- Rear Tube Bumper 98 4runner
- Tacobox-planetary doubler idea
- light bar question
- turning a propane tank into a gas tank
- Cracked Frame is it worth it?
- Build onto flatbed or start over?
- Custom soft top - frameless
- narrowing the frame?
- 3rd Gen Front Tube Bumper
- Slow 3.0 Snorkel Build-Up
- how much yall reckon it'd cost to build
- Lumber rack & tailgate w/ spare tire
- Anyone in the PHX area interested in fabricating their own designs?
- skid for lifted
- another tube rear bumper.. trail gear rip off
- Custom Snorkel Air Filter Remount
- custom front and rear bumper build finished. Check it out
- Square Drive shaft.
- Roof rack mounts..
- Can I move my rear axle foward with Cevy springs.
- More sliders.
- anyone ever build their own t case and transmission skid
- Made my own short shifter
- trail-gear bumper measurements
- E-locker swap into 1980 toyota
- steering stabilizer placement with high steer
- 1st gen 4Runner bed top rails Herculiner?
- Giant brand beams on a toyota
- buliding A exo cage and tube bed need some help
- Cable Triple Sticks-stupid idea
- Help on custom bumper fit!!!!
