how can i bend a frame?
Old Dec 12, 2013 | 08:19 AM
andy4x4's Avatar
ok so my buddy flipped his 83 4x4 and we did a cab swap and found out the front of the frame on the passenger side get bent down like 2 inches. is there any way that we can bend it back? i does not need to be no show truck fix just a at home do it your self fix. thanks for any help guys.
Old Dec 12, 2013 | 09:02 AM
scuba's Avatar
You can try with a winch, highlift, come-along, and some heat in the right spots.
However, I'd just take it to a body shop with a frame machine and have them do it right.
Old Dec 12, 2013 | 09:03 AM
redbayredneck's Avatar
Agreed, you want it to be done right so that the frame doesn't break in two with the first speed bump you hit.
Old Dec 12, 2013 | 09:15 AM
Terrys87's Avatar
A frame shop should not charge that much from what you are describing. Shop around and think you will be suprised at how cheap it can be done and be done right.
Old Dec 12, 2013 | 09:22 AM
andy4x4's Avatar
we cant really take it too a shop, we need it some what straight to weld the new front hanger on, and he does not have any more money to spend so we cant take it to a shop
Old Dec 12, 2013 | 07:46 PM
crazypaint's Avatar
Tie it down to the floor oright behind where its bent. Use a jack on the front of the rail anf apply lots of pressure with the jack. Use a sludge hammer over top of the bend in the frame obviously hitting that point also the sides. Add more pressure and repeat. Measure the rail as uou go. Measer the none bent one so u have abidea where u wanna be
Old Dec 13, 2013 | 02:21 PM
wyoming9's Avatar
Red face
Since this is a ghetto Fab job at best!!
I say frame machine but seeing that is not an option.
Will this vehicle be used ever again on the street??
You need to be pulling or pushing beating with a hammer will only get you hurt
If it was me I would cut the damaged piece out and splice in a new piece .
it would be where it needed to be it would be new metal and one heck of a lot easier and take less time and be safer.
Old Dec 13, 2013 | 05:17 PM
andy4x4's Avatar
if it was up to me i would take it to the shop lol but this kid is so stubbornhe wont do it, and yeah i know its going to be a ghetto fix but as long as it is drivable its fine he says
Old Dec 14, 2013 | 01:04 AM
wyoming9's Avatar
Red face
Sometimes the best action is to walk away!!
without pictures and even with pictures to move a frame 2" had to taken a real good hit.
What else might have been over looked.
Old Dec 14, 2013 | 05:48 AM
Team420's Avatar
sounds like you already figured out how to bend a frame
Getting it bent back wont be easy, and may not be safe after.
I personally would use chain cinches to tie it down (hope you got A lift) and maybe an engine hoist to lift up on the frame.... and lots of heat. Depending on the engine hoist, you may need something a bit stronger. Good luck!
Old Apr 11, 2014 | 08:49 PM
thefishguy77's Avatar
Running over a Honda CRX will do it to. Parts truck frame was hammered
Old Apr 14, 2014 | 05:45 AM
nothingbetter's Avatar
crazy paint has the right idea. That how we're trained to repair frames in "bodyman school" Splicing would be a waste of time and much more possibility for a failure down the road.
but you don't need a sledge hammer. 2lbs is lots. All your trying to accomplish is to normalize the steel and use its memory to bring it back in shape. Its under tension, so apply pressure in the way it has to go and tap a LARGE area with your hammer. this moves the metal molecules back the where they should be and removes stress throughout the frame rail. Slow and steady is key.
Old Apr 14, 2014 | 05:46 AM
and in theory, heat should not have to be used.
Old Apr 15, 2014 | 04:32 PM
wyoming9's Avatar
Red face
Welders tend to do things different then body people and most everyone else as well.
to each there own.
Old Apr 15, 2014 | 04:44 PM
85TurboRunner's Avatar
Thats what I'd go with also.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
RDubya
Feb 10, 2017 04:46 PM
live4soccer7
May 11, 2016 06:52 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
