steering stabilizer placement with high steer
Old May 21, 2013 | 10:42 AM
dropzone's Avatar
Fossilized
Been searching various boards trying to get a clear picture of how people have placed a steering stabilzer with high steer but no luck getting a clear example.
Here is what I have to work with.
I know the fixed end needs to go on the p/s.
Old May 21, 2013 | 12:00 PM
irab88's Avatar
mount it like a hydro-assist ram?
Old Jun 9, 2013 | 09:51 AM
earthbound's Avatar
Hey, I'm in the same spot as described in the OP, except I'm working with an 88 pickup. I know I'm supposed to attach it (via ubolts) to the drag link, but the perfect spot on the passenger side frame rail is eluding me. I would think it's gotta be either directly above the drag link or just to the rear of that spot. What do you think?
Old Jun 10, 2013 | 09:38 PM
4Crawler's Avatar
My old setup, tab welded to the front edge of the spring plate:
- http://www.4crawler.com/4x4/CheapTri...ringStabilizer
Old Jun 11, 2013 | 05:42 AM
egesledder's Avatar
I'm running the All-pro setup. It comes with tabs to weld to the frame, the u-bolts and plate for the drag link, and a damper. Seems to work pretty well and its not in the way of anything.
Old Jun 11, 2013 | 08:39 AM
earthbound's Avatar
I'm running the Trail Gear IFS Eliminator kit. After mocking it up and extending the stabilizer halfway, it became pretty apparent that the proper spot is slightly in front of the drag link, behind the two weep holes on the bottom side of the passenger frame rail.
Old Jun 14, 2013 | 03:31 PM
AaronM's Avatar
With the stabilizer mounted to the spring plate was there any problem with clearance between the shock body and the axle housing?
Old Jun 14, 2013 | 04:37 PM
SCToy's Avatar
the way earthbound has it is how I planned to do it, but I haven't gotten around to installing it. Never felt i needed it.
Old Jun 16, 2013 | 12:54 AM
an1mal_69's Avatar
I've armoured the diff (similar to post #5) and mounted off that..
Old Jun 16, 2013 | 05:17 AM
dropzone's Avatar
Fossilized
i ended up doing it similar to earthbound's
delmert
Sep 30, 2015 04:34 PM
priest16
15
Aug 6, 2015 07:43 AM
Up&Down
Aug 5, 2015 06:20 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
bobpat
Aug 1, 2015 09:25 PM
