View Full Version : The Fab Shop
Pages :
7]
- Punchin Out #036
- Porsche Cv shaft length help ??
- Thanks Waskilly for my new bumper
- Ultimate Tacoma Light Bar build up
- bobbing your bed
- tube bumper on a 89 4runner
- turn signal relocation, custom winch bumper
- First Project w/ new Tube-Bender...
- I need a little information on connecting a rear bumper
- new skin ......
- 1st gen 4runner needs roofrack!
- Homebuilt TIG welder
- Slider attachment question (weld/bolt)
- another set of rock sliders...
- Roll Bar or Cage and Lumber Rack?
- Attn: Robinhood Bumper Pics
- ORS coilover kit
- misinformation
- rear lift shackles
- tube bumpers,rock sliders
- 3rd gen rear bumper build
- BLING BLING modified TJM
- SAS front hanger mount
- Mig welder regulator question
- winch bumper v2.0
- Importing an older double-cab?
- welding/cutting kit
- Welding Aluminum
- What year Land Cruiser rotors?
- extended a-arms
- 1st Gen Bull Bar Build
- My FJ40 Buildup
- Ranski's 85 4Runner Buildup
- BruceTS-inspired rear bumper
- Rear Tire Carrier Pivot Point
- marlin front bumper
- What's the consensus on the new Rubicon Express "Builder Ball" joint?
- 2nd gen 3-Link rear with Coilovers
- fold down tire carrier
- Ways to increase tongue weight capacity?
- Stingers?
- pipe notcher
- trail-gear vs. marlin SAS kit
- moving trans to change center of gravity
- ARB bumper ends sticking out
- cost difference: 2nd gen SAS vs 3rd gen
- Custom 2nd gen rear bumper
- Seafleas IFS Elimination
- looking for motor adaptor kit
- E-locker Retrofit
- Double Cab Coilover SAS
- 3rd gen rear bumper pics/progress!
- Custom snorkel build-up
- Custom Roof Rack??
- Another Custom Tube Bumper
- Uniballs for long travel fronts?
- 3-link Joint options??
- 1st Gen ARB mounting pics?
- SoCal/Bako area elocker modder?
- Steel fabrication work required - SoCal
- Keep my874runner and build it, Or buy my96landcruiser?
- 90 4runner SAS W/37's
- Tranny Question on my Rock Buildup..
- ORS custom cross-over for 3.4 swap
- converting 2wd to 4wd 04 taco
- How to TH350 a 22r
- 2 link vs. 4 link SAS?
- Converting a 2WD to 4WD questions
- 7mge swap question
- Build Up of a 92' 2X
- Sophomore Design
- I need axle info please
- Another tire carrier design for rear bumper...
- How to get accurate angles when welding
- Plans for rear bumper bar 1st gen
- Cutting my frame need advise
- pic of custom roof rack
- Fishing Pole Rack/ Cooler Basket
- Custom front winch bumper and rear
- catalytic converter
- tank mount
- I Need a Custom Hitch!!
- my bumpers
- Bobed Top third Gen
- New Ram Tube Injection Project
- toyota 4LINK HELP
- fab supplies
- Center Console
- THE 1 MILLIONTH SAS (on my 92 runner)
- hummer portals for IFS
- CUSTOM OPTIMA BOX & BRACKET FOR WARN CONTROLLER
- Defelice Prototype axle truss
- Remote rear window in 1st gen
- Organic Fab...only two bumpers like it.
- Custom topper for bobbed bed
- Anyone Regret Replacing 4runner Rear Coils with Leaf Springs?
- Quick question, radius for rear bumper
- Who will build me a 3rd Gen Rear Bumper?
- Anybody ever made a Bikini Top
- Sliders with dropdown\removable steps?
- the dirt cheap SAS........well close
- fartruk redo pics
- rear bumper
- Tacoma custom rear bumper
- Pics of the flatbed project
- engine choices
- Solid Axle Swap Has Begun!!!!!
- new guy with some bumper questions
- Finished my Rock Sliders
- My winter rebuild (7MGTE overhaul)
- For those considering an "M" series swap (5M/7M)....
- '90 4runner SAS Project
- Custom bumper supports
- twin stick
- 3rd Gen. Roll Cage
- Toyota CV joint... High angle vs Low angel???
- Fender Gap Cover
- How to give the 3rd Gen 4Runner a flat bottom...
- 3.0 to what? need help
- Lions tigers tacoma motor swap oh my
- Really long rear shackles? 12 inchers?
- Liar Liar Pants on Fire
- Ford 302/351 swap info
- Body mounts
- What all is needed (from 85 donor for SAS on a 91)?
- Sacramento CA Shops
- Diamond Plate Sheet Metal
- All Pro Off Road Warranty
- Metal supply shop in Las Vegas?
- 3.0 engine swap questions
- Need to cut a section out of my cab mount .
- Another 3rd gen SAS
- all pro disc parking brake kit question
- bamachem 3rd Gen Bumper w/ Tire Carrier Build-up Thread
- pickup gate for 4 Runner
- Winch mount plate for ramsey winch
- Relocating tcase Cooler ?
- ? on value of 85 mini front axle
- My 2nd Gen 4Runner Buildup. SAS, Duel E-Lockers, Full Exo and more…
- Designing my new rear suspension setup...
- 3RD GEN : Ander Engineering Rear Bumper Build Thread...
- What's the best way to teach oneself to weld/fabricate
- Wicked suspension
- 1991 2nd Gen SAS way eaiser than a 3rd Gen
- Rear coils???
- re-welding to the frame
- Limited Fender, Pinch Weld and Floor Trimming
- cheby pwr str pump to '86 yota box ?'s
- bumper build-up...
- Rebuilt Front Cross Member on 2nd gen 4Runner
- 2nd gen measurements
- My '85 p/u build-up.
- bumper build's goin good...
- Welder recommendation
- Recaro seat brackets for Tacoma
- 2nd lower control arm mounts
- Pressurized Shower!!
- 2nd Gen 3 Link/Housing Truss
- hrew or dom
- ARB Install - Unitrax in Anaheim
- Any one know a good welder in Corona, Ca?
- Fabbing a new bumper
- Put a Roll Cage in my 2nd gen 4Runner
- Rear Lockout Hubs???
- 3rd gen rear bumper building
- Rubicon Express joints with Rear leaf swap questions
- Pics from 3rd gen 4runner rear bumper build
- Body lift bolt length
- Name that Part
- T-17 Modification
- Had to start My own build up thread.
- Modified TJM brackets for 2" body lift
- My first engine swap.
- Can't weld to Toyota frames...?
- Website that might useful to some of you
- GPS / LapTop Off Road Sturdy-Mount
- Clocking a Tacoma T-case
- to swing-a-way or NOT to swing-a-way with the tire carrier?
- New Front Bumper
- Best way to contain grinding/ cutting sparks
- Bad boy tube chasse. Made to your specs in Appleton Wisconsin
- so i roled it
- winch bumper...done
- Welding Gas Question
- Engine Swap
- 64 FJ 40 axle swap
- Motor Mount Location when swapping to 4.3?
- help on bumper fabrication
- SAS w/ ARB Modifications
- Driveshaft spacer
- new tube bumper
- Titan 1 - My 3rd Gen Rear Bumper
- Diesel Swap Question
- SAS w/ coils...
- willing to make a 4th gen bumper ?
- Long Travel Front Shocks
- Welder recommendation in So Cal
- What to do when you remove stock Bumper BUILD Checker Plate Bumperplate
- Peek-A-Boo Snorkel CUSTOM
- SteveO's SAS
- ford v6 in my 84?
- ford v6 in my 84?
- Is heating steel tube bad?
- 3rd Gen SAS Help
- Formula type buggy build
- do you need something welded ?
- Cage ideas...
- welder bling
- Teaser pics
- Chopped 4runner??
- metal thickness for flatbed ?
- Tuned Port Corvette, Supercharger Into 3rd Gen With Emissions?cebby Inspired Me
- Tire Carrier build-up
- rotors for sas
- winch mounting dimensions
- Flex shots of 3rd Gen 4Runner SPRING OVER SAS
- 3rd Gen fuel tank build-up
- tire carrier.....done
- half doors and legality???
- Tube Beds and Truggies
- toyota rear into jeep?
- IFS frame brace
- "05 Tacoma SAS
- 3 Link my 4Runner NO MORE Panhard bar
- dual battery trays under flatbed?
- Bed Rack/Cage in progress *Pics Galore*
- second tcase on the cheap
- Pathfinder finally done!
- built a battery tray today....
- Buying Steel
- Unconventional Skid plate material...
- Custom rear shock mounts
- Long travel shock mounts
- sas questions ?
- tube bumpers and tube prices (2005)
- 2nd Gen Runner Rear Upper Shock Mount
- getting better.....
- Hey badland bumper people
- Solid Axle Swap
- 4th Gen bumper build-up
- SAS Parts List and Pricing
- Time to paint the 1st gens pics 56k!!!!!
- runner 3 link in rear
- Armor and tool ?
- Rear Bumper build up
- 1997 Runner Bumper Build, Acquired Materials, About To Start, Ideas? Thoughts?
- swapping in tacoma rear axle to pickup
- rear springs up front
- 1999 4Runner Dana 44 SA Conversion and Rear Leaf Conversion - Pics and Writeup
- buddy is confused about his 94 pickup
