What's the consensus on the new Rubicon Express "Builder Ball" joint?
Old Mar 4, 2006 | 04:29 PM
Cebby's Avatar
This one:
The hole accepts 3/4" hardware. They are using either this one or their 5/8" model with in their Tri-Link kits. Basically they can eliminate the trackbar (panhard) with this setup. This joint is mounted on top of the diff with two links meeting at it and then the lowers are typical links.
Whomever is considering a 3 link rear for their 4 Runner, this might be an interesting option.
Old Mar 4, 2006 | 09:05 PM
ravencr's Avatar
I heard they were coming out with a bigger one, but never saw the pictures or specs.
Chris
Old Mar 5, 2006 | 07:05 AM
dragr1's Avatar
Not sure about the big one, but the smaller one's Steve uses on his lower control arms are sweet and flex great.
Old Mar 5, 2006 | 10:05 AM
Cebby's Avatar
These items aren't the ones Steve is using. He's using the RE Superflex joint. These are much much larger. These are roughly 3"+ in diameter.
Old Mar 5, 2006 | 10:07 AM
Cebby's Avatar
Steve uses something like these:
(That's the large version - theres a smaller one than that)
Old Mar 5, 2006 | 10:13 AM
dragr1's Avatar
Correct, I was just stating the smaller ones that Steve is using are very nice units.
Old Mar 5, 2006 | 11:21 AM
Napoleon047's Avatar
why does everyone want to ditch their panhard?
do they just not understand the benefits of having a panhard or what?
Old Mar 5, 2006 | 02:23 PM
Cebby's Avatar
Do you have any constructive feedback on this RE joint? That's the question.
There is one benefit to having a panhard - that's to locate the axle from side to side If there are more benefits, we're all ears. Many 3 and 4 link designs don't require a panhard because their design inherently keeps the axle located under the vehicle.
Old Mar 5, 2006 | 05:11 PM
motoracer47's Avatar
other reasons would be:
panhard bar does not keep the axle perfectly centered through its full range of articulation. some have seen 1/2" movement to the passenger side with just a suspension lift. the tri-link cebby is refering to will take the place of the panhard, using the above joint ontop of the diff housing for lateral location of the axle. it would be stronger, maybe lighter, and for sure better (suspension geometry wise) than the stock panhard bar.
btw, looks like a quality piece, but i have no idea. looks nice though.
Old Mar 6, 2006 | 08:57 AM
ok, ill start another thread on panhards to keep this one on topic.
as for the joint, i assume you are planning to use this joint for the center joint on the wishbone? if so, i would go for it over the standard RE joint. that single joint has to do a big job. it has to center the axle, and keep the axle from wrapping.
Old Mar 6, 2006 | 09:07 AM
Cebby's Avatar
I think that is the whole purpose RE came out with this one. The standard RE joints aren't beefy enough to do all this stuff with one joint. They are using it in their tri-link systems now.
Even with this robust joint, there is still the gas tank to contend with.
Old Mar 6, 2006 | 10:33 AM
leave the gas tank where it is and 3-link it
Old Mar 6, 2006 | 10:43 AM
Cebby's Avatar
I like that one. Airshocks - Mmmmmm.....
Old Mar 6, 2006 | 11:35 AM
ravencr's Avatar
I don't think air shocks will work on our rigs. Too heavy, although I'd like to use them too for simplicity sake. Peter, please post the link to the panhard bar thread once you do it. Thanks,
Chris
Old Mar 6, 2006 | 11:45 AM
Cebby's Avatar
Originally Posted by ravencr
I don't think air shocks will work on our rigs. Too heavy....
I had heard that same thing. Mine will certainly not be any lightweight!
Old Mar 6, 2006 | 12:05 PM
actually, now they have 2.5" and 3.0" airshocks, i highly doubt a 3rd gen is too heavy for a 3.0" airshock
Old Mar 6, 2006 | 12:06 PM
ravencr's Avatar
I wonder, and it might be something to check out.
Chris
Old Mar 6, 2006 | 12:08 PM
http://www.polyperformance.com/shop/...&cat=34&page=1
fox 2.5" shocks
double the load capacity of the 2.0" shocks
edit: i put the panhard thread in offroad tech
Old Mar 6, 2006 | 12:13 PM
ravencr's Avatar
So what does that make the capacity of them now?
Chris
Old Mar 6, 2006 | 01:29 PM
Cebby's Avatar
Chris
You still should cut the back off of your Runner either way.
