help on bumper fabrication
Old Aug 24, 2005 | 08:55 PM
TennRunner's Avatar
Question help on bumper fabrication
I'm ready to build bumpers for my 87 truck. Ive had good amount of welding experiance, but not much fab work. I have access to a pipe bender and every thing I need. I want to use round tubing, because I have access to the material FREE!!! Does anyone have advice how to mock up a pattern to get started without wasting time and materials? I'm starting on the rear, since their is less bending and alignment issues than in the front. I could use some example pictures if possible,
Thanks for your time!
Old Aug 25, 2005 | 05:23 AM
GreeneHoosier's Avatar
If this is your first foray into bumper fabrication I would go simple. Remove bumper and brackets from truck, tack weld brackets to fixture (table) (allows for perfect spacing)and then measure bumper and remove. Cut tubing to same width as bumper and then weld to bumper brackets. Cheap easy and looks mean. Double them for better visuals. Good luck.
Old Aug 28, 2005 | 07:34 PM
934rnr's Avatar
Here's mine it's pretty simple.
Old Aug 29, 2005 | 06:32 PM
Napoleon047's Avatar
cheapo bender as well
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
Scotttekoch
Sep 28, 2015 10:30 PM
83
Sep 27, 2015 04:13 PM
Toys4parts
Sep 26, 2015 01:56 PM
