My first engine swap.
Old Sep 9, 2005 | 03:55 PM
Dobi's Avatar
My first engine swap. (big pictures dialup beware)
Here is my attempt at a writeup. Please forgive if it isn't overly useful.
Donor Truck: 1993 S10 Blazer w/Vortec 4.3 V6 motor. Vin type W
First things first. Had to Clean the shop.
Then made sure the engine ran. Which it did quite well.
Then for marking all wires. I put a piece of masking tape around each wire with a number on it. I took a picture of each # and wrote down where they went on the motor.
After all wires accounted for, time to start plucking them all out (what a mess)
And pull the motor:
Once motor out, time to bolt on the TH350:
and the NP203:
Altogether and look'n good.
Next for the even dirtier stuff, the Yota.
Old Sep 9, 2005 | 03:56 PM
Dobi's Avatar
Had to pull the stock 22r out:
Sandblasted the engine compartment and re-sprayed it:
Now thats all clean, time to put in the Vortech:
Make sure the transfer case is centered with the old transfer case:
And for attaching the Mounts http://www.advancedadapters.com :
The mounts are 19.5 inches from the longest point on the frame. That gave me a little less then 2" of clearence between the firewall and the distributor. Plenty to get it on and off and run all my fuel lines.
More writeups to come:
Wiring. (done, yes, Done. the wiring harness was a beast to tame but due to a couple good mechanic friends and a nifty proggie called Shopkey Pro it was a cakewalk.)
Transfer Case X-member. (in progress)
IFS Power steering(here) & X-over steering (shipped yesterday, somewhere between MarlinCrawler and Columbus,GA)
Front Shock Hoops(same as xover) & YJ Lift springs up front.(here)
63" Chevy rears.(here)
FlatBed(in progress)
Old Sep 9, 2005 | 05:38 PM
NCSU-4runner's Avatar
looks like you already know alot about what you are doing for your 1st motor swap, sure are alot more organized than i was. good luck
Old Sep 9, 2005 | 07:40 PM
DudeBud's Avatar
looks good keep the pics coming
Old Sep 10, 2005 | 06:38 PM
44Runner's Avatar
Is there a doubler in the future? Otherwise I don't understand why you went with a 203...
Old Sep 10, 2005 | 08:05 PM
Dobi's Avatar
I have some rough hills between my house and my fishing hole. Pulling my bass tracker was just kill'n the ole 22r. so I pickedup the 4.3 for next to nothing. I traded my worn out stock manual drivetrain for $500 and a TH350 brand new rebuilt with 1yr warranty and the np203. The bolt-on ability without adapters was worth the downgrade. (guy has good money and his son blew his last motor)
Doublers is definately in my future. just not immediately.
I've been wanting to go automatic anyhow for the mere fact that i weigh close to 300lbs and shifting gears while sideways while trying to keep gas in the carb has just become too aggravting for me
Old Sep 22, 2005 | 12:51 PM
braverex's Avatar
Looks real nice!
Old Sep 22, 2005 | 02:25 PM
getitdone's Avatar
Cool! I remember when I wanted to do this swap, my girlfriend at the time had a clean 4.3 s-10 blazer for a donor and then wrecked it.
It was a bummer, but I'm too much a noob for this kind of work anyway.
Old Sep 23, 2005 | 06:26 AM
99_Runner's Avatar
Very nice. Any updates or pics.
Old Sep 25, 2005 | 04:07 PM
Dobi's Avatar
I actually got the engine running. Didn't have the oil cooler on it though (DUH!!) so oil went everywhere. Was kinda rough but I'm guessing that was because it was open manifold so it had no back pressure, O2 sensor or the intake sensor wasn't on it either
I will do some pics this week. I have put 4" lift YJ rears up front and 63" chevy springs in the back. its ALOT taller now. I'm getting excited.
Stuff left is Finishing the x-over steering, radiator/oil & tranny cooler mounting, permanently mounting chevy gas tank. Then its off to the drive shaft shop. Then off to the exhaust shop. Then bring it back for mounting the front shock hoops(still gotta buy some shocks too), put on the extended brake lines.
Started to mount the '86 pwr steering box tonight but while drilling the mounting holes the drill is going so getting a heavier one to use tomorow night.
Old Sep 26, 2005 | 12:19 PM
Dobi's Avatar
Here's the front lift. dwarfing them 33x10.50's
Old Sep 26, 2005 | 07:37 PM
Dobi's Avatar
..........having a hard time getting the radiator to fit with the pwr steering box.
Old Sep 26, 2005 | 07:47 PM
bob200587's Avatar
love that motor....nice set up Chevota's are awesome
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
