Cutting my frame need advise
Old Jan 20, 2006 | 05:50 PM
yoda92's Avatar
Ok so I have never attempted anything like this before . The only tools I have for the job is a reciprocating saw to cut the frame. So I need to know how I should cut my cab mount horn so that (A) It will still be structuraly sound and (B) I can box the cut out part back in
The pictures here are of the cab mount , I have colored in the area that I need to be cleared out so Im not rubbing anymore. I want to make sure there will be clearence when the suspension is compressed.
Old Jan 21, 2006 | 06:35 AM
ravencr's Avatar
Just chop chop and you'll be fine! Just make sure you replate it, because the force could bend it.
Chris
Old Feb 18, 2006 | 01:21 PM
Get a 4 1/2 angle grinder. Find one you can put an abrasive cut blade in. I would use that instead. Don't force the cut. Let the tool do the work. If you do use the recip, keep the blade fresh or you might go for a ride.
Old Feb 18, 2006 | 01:54 PM
waskillywabbit's Avatar
I 2nd the angle grinder w/ a cutting disc. You will have a LOT more control. You are going to have a hard time cutting that w/ a sawzall IMO due to space.
From what you said this is a body mount and as long as you rebrace it you won't have a problem. Looks like the front body mount right by the firewall behind the front tires. I clearanced my front fender well all the way back to the front cab body mount, but never got into it
However, is there not something else you can do to eliminate this issue? Sure it might cost more, but it would also fix it properly as opposed to hacking off metal. Just asking.
Keep us posted w/ what you do...w/ pics!
young buck
18
Aug 27, 2018 02:40 PM
RobotMoose
Sep 2, 2015 05:53 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
DrZero
18
Jul 24, 2015 11:31 PM
