Engine Swap
Old Aug 28, 2005 | 04:52 PM
madbronco's Avatar
Question Engine Swap
Hi guys and gals, you people have a great site. their isn't many people up here that Yota's but anyway i have 90 truck with a 3.0, well it used to have a 3.0 in it . I am in the process of swaping in a 4.3 with a 700r4 tranny, I am thinking of keeping my transfer case but was wandering if it would handle the extra power of a 4.3. was also wandering if my transfer case will stay in the stock location? ANY help would be greatly apprecated THANKX
Old Aug 28, 2005 | 05:04 PM
Silver_Truck's Avatar
I'm sure it would be able to hold up to the power but if you've got some money I'd try and track down a gear driven case but you'll need a 23 spline one. That way you can go dual cases, get new gears etc. down the road if you want to.
Old Aug 28, 2005 | 10:22 PM
DudeBud's Avatar
my 21 spline t-case handles the power of the healthy 302 in front of it
Old Aug 29, 2005 | 12:48 PM
rockota's Avatar
Tcase will *NOT* stay in teh stock location, and if you want it to do so, I'd recommend skipping the swap. Position the engine where you want it and let the rest fall in place.
I also recommend upgrading to the 23 spline input shaft. It's cheap insurance.
Old Aug 29, 2005 | 06:04 PM
madbronco's Avatar
Ialready have a 23 spline transfer case. why wouldn't the t case stay in the stock location? I have done all the measurement and everything say's they will . thats if i use the advance adapter kit for mating a 700r4 to a 23 spline transfer case. Am i missing anything. what about headers will i be able to use my stock 4.3 manifolds or am i going to have to use something else?
Old Aug 30, 2005 | 10:42 AM
DudeBud's Avatar
im calling bs on you cant get the tcase back in the stock location. 4.3 chev is a short motor even and with a short water pump there should be plenty of room to get the case where it has to go. cheak out this thread. https://www.yotatech.com/forums/f88/1wicked_runners-rig-56881/
Old Aug 30, 2005 | 10:54 PM
upndair's Avatar
Markus project DID put the t-case back in the stock location. With the AA adaptors you can mount the t-case in position and let the engine sit whereever it needs to. In the thread that you pointed to, the T-case most certainly stayed in the stock position. That was a critical point because we had a dual t-case setup along with custom drivelines that required keeping the t-case where it was.
Old Aug 31, 2005 | 08:43 AM
DudeBud's Avatar
yep thats the nice thing about using a 4.3 and AA adapters
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
