2 link vs. 4 link SAS?
Old Jan 31, 2006 | 07:51 AM
DH6twinotter's Avatar
Hey all,
This thread is really going to show my ingnorance on this but I had a question regarding SAS. What are the pros and cons of using a 4 link over a 2 link (I guess it called a 2 link?)? Seems that every coiled SAS done on a Toyota I've seen has been a 4 link. Now this link shows a Xterra coiled SAS kit for sale that has just 2 links:
http://www.xterraownersclub.com/revi...ini_sas01.html
Are there any benefits to using a 4 link over a 2 link? With the 2 link it seems that the front 3rd and driveshaft will remain at the same angle in relation to each other, no matter how much flex is being excerted on the rest of the suspension. Is this less stress on the u joint? Would the pinion get enough lubrication with this set up?
Would a 4 link provide better flex?
Sorry for the stupid question, but just something I was wondering about.
Thanks all.
Daniel
Old Jan 31, 2006 | 08:15 AM
Napoleon047's Avatar
the "2 link" is more commonly refered to as radius arms
FJ80s, and the "long-arm" jeep lifts all use radius arms.
the difference isnt really in flex, its in the handling of the vehicle and suspension.
4links are generally better because of the way they handle and maintain the caster of the axle, as well as redundancy (if you trash one of the links, you still have a chance of driving out, whereas with radius arms, if you trash one, you are done)
in the front of a rig, with the engine and steering components, 4 links are hard to fit. most people go with a 3 link (2 lowers, one upper) and a panard. it has similar performance to a 4-link, but is much easier to fit
Old Jan 31, 2006 | 08:32 AM
bob200587's Avatar
this is one of those things I never understood either. suspension can be so baffling. I still don't know what a panhard bar is.
Old Jan 31, 2006 | 09:16 AM
Cebby's Avatar
Panhard bar's only job is to keep the axle centered under the vehicle.
The Calmini is a radius arm with panhard. In essence its a 3 link.
Most of these dual triangulated 4 link setups you see on the web don't need a panhard because the triangulation locates the axle.
Our 4Runners need the panhard because the rear links aren't triangulated (making it a 5 link).
Old Jan 31, 2006 | 09:20 AM
Cebby's Avatar
I have a great article I found in JP about suspension systems. I'm planning to scan in the pics and article and post them up.
Old Feb 2, 2006 | 07:25 AM
Thanks all! So, is a 3 or 4 link more durable? Seems like under extreme flex, radius arms would twist like a torsion bar. With links, a person could use those orbit eye type of mounts to keep this from happening, right?
Also, what's a heim?
Old Feb 2, 2006 | 07:27 AM
Cebby's Avatar
Heim aka Rod End...
http://www.polyperformance.com/shop/home.php?cat=154
Old Feb 2, 2006 | 07:33 AM
Oh, ok. Thanks!
When people are counting the number of links on a vehicle, do they usually include the panhard bar? Do they say 4 link, or 3 link and a panhard?
Thanks! Sorry for the stupid question.
Old Feb 2, 2006 | 07:54 AM
Cebby's Avatar
Seems theres no set standard (not that I've seen anyway). Some folks say "# link with panhard", some call every rod that connects to the axle a link.
BTW, another name for a panhard bar is a trackbar (that's what they call them on Jeeps from what I've gathered)
Old Feb 2, 2006 | 08:00 AM
Oh, I forgot about the trackbar! Now that you mention it, they talk a lot about trackbar adjustments on NASCAR.
Old Feb 8, 2006 | 06:45 AM
Another question: Is a Johny joint pretty much the same thing as a Heim except that it is rebuildable?
Mods, if you want to move this to the newbie section, thats cool with me. These are newbie questions, I think.
Old Feb 8, 2006 | 07:44 AM
Praufet's Avatar
yes its pretty much the same thing. The johnny joint is better for a number of reasons. Rebuildable, made for off-road, tougher races, and tougher material.
Old Feb 9, 2006 | 07:03 AM
ah, ok thanks.
ashamsuddin
17
Jul 22, 2024 03:59 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
