Buying Steel
Old Jun 24, 2005 | 12:17 PM
MellamoPOUND's Avatar
Buying Steel
Now that I have some time off this summer, I'm working on repairing my skid plates and painting everything that has been scratched from off-roading and is now rusting. Last summer I made the tcase skid like transalper (sp?) with 3/16" steel. The plate is now all bent up and needs to be hammered back and given reinforcement. Since I'm on a very low budget and I don't know how to weld, I'm thinking of just adding some strips of 1/4" steel through the tcase skid bolts from one cross member to the other. Hopefully this will add the much needed strength.
My problem is that I can't find a good place to buy raw steel. For the tcase, I had to go to this steel place which usually sells their products to huge oil rigs and NEVER to individuals for 4x4's. They were very confused, had trouble cutting the huge pieces of steel to my plan, and charged me too much. I have called ACE hardware and Home Depot and they both dont sell steel. Where would ya'll reccomend I pick some up?
Old Jun 24, 2005 | 12:45 PM
crawler#976's Avatar
I'd check the yellow pages for steel building construction businesses. they often carry supplies for resale.
http://www.superpages.com/yellowpage...T-New+Orleans/
Several of the companies in the list above should be able to supply your needs.
I go the the swap meet when I need angle iron. There are always old bed frames for sale - CHEAP!!!
Old Jun 24, 2005 | 01:18 PM
RLJ3RD's Avatar
Try a welding supply retailer. Usually they have access to or sale metal stock. They should at least be able to direct you in the right direction.
Old Jun 24, 2005 | 02:17 PM
Right-O. Thanks!
Old Jun 26, 2005 | 04:01 PM
mv5841's Avatar
Hey man,
Since you are local, I suggest you check out Dencol. Its a HUGE steel place...I mean they have a hardware store, a steel cutting warehouse, ect.
Check the remenents section, you can pick up precut pieces of steel for cheaper than buying em new.
Den-Col Supply
4630 North Washington Street
Denver, Colorado 80216-2744
Old Jun 26, 2005 | 06:15 PM
toytube's Avatar
metal
there are a few places around denver that you could check out...if you need some welding done and are in denver area....i can do it...give me a call 303-680-9077 if you need some welding or any help with the fab end of things...
try den-col, K&K, tube services.....those three should have what you are looking for....
Old Jul 6, 2005 | 05:49 PM
BOSTON4RUNNER's Avatar
Also go to local manufacturing places and maybe if you know someone at the local transit authority (buses/trains)
you can score some good used/scrap steel from them
wberry85
Apr 6, 2018 08:45 AM
icentropy
Sep 10, 2015 05:03 AM
AkitaDog
Sep 3, 2015 09:01 PM
mirabile4runner
Sep 3, 2015 07:15 AM
