2nd lower control arm mounts
Old Sep 27, 2005 | 01:49 PM
Praufet's Avatar
Ok so I had this idea. I can see the lower control arm mounts getting hung up on stuff (the ones that attach to the frame). So I though about making mounts that would actually be in the frame. i.e I'd cut in to the frame, weld in reinforcements and the use that as a mount. It'd allow for longer control arms and a flatter belly and it'd look cool. The only question I have is: would this screw up the suspension geometry a lot? I could have my roommates crunch the numbers but thought I'd post it here first and see what people thought.
P.S.-I have a really badass bumper design that I should be able to build over xmas break.
Old Sep 27, 2005 | 01:53 PM
00Runner's Avatar
How will you allow for uptravel if the links are in the frame?
Old Sep 27, 2005 | 01:57 PM
Ric's Avatar
Ric
Banned - User requested
funny i should read this, ive been talking to Jed at Armorology about this very subject, we wont cut into the frame, but he will some how make new mounts that are shorter and stronger, this isnt going to be a priority, but its on my list.
let us know what you come up with, and keep us posted, when we get around to mine, ill do the same.
Old Sep 27, 2005 | 01:58 PM
Praufet's Avatar
Hmm. Let me draw a pic.
something like this:
also does anyone know what the circled part is or does?
Old Sep 27, 2005 | 05:03 PM
Flygtenstein's Avatar
Yes it will fudge the geometry. Those links are short and finicky.
Advice? Brace them and wheel it. Buy my links in a couple weeks and give it hell. I doubt you will be using the truck as hard as I did and this rear set up works perfect.
Old Sep 27, 2005 | 06:59 PM
Praufet's Avatar
What is your rear setup?
Old Sep 27, 2005 | 07:34 PM
BruceTS's Avatar
You can easily relocate the mounts, but you'll need to recalculate your roll center and anti squat numbers. Use the 4-link calculator provided on PBB, being off by a 1/2" makes a huge difference........
88sasturbotoy
Jan 30, 2026 01:57 PM
kirkrunner
Jul 27, 2015 07:59 PM
KyleT
Jul 21, 2015 07:54 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
1994toyota
Jul 17, 2015 03:03 AM
