pipe notcher
Old Feb 26, 2006 | 04:07 PM
JonathanG32's Avatar
pipe notching ???
i am building some rock sliders and now i just need to know how can i notch the ends. i bought a harbor freight tools one but that did not work i was thinking of just gettin a grinder to grind it but that might not come out straight any suggestions on how to or know any one that has one around the denver area or where can i order one from a web site that is not expensive because i will not be using it on a daily basis. thanks
Old Feb 26, 2006 | 04:25 PM
midiwall's Avatar
Sorry to say, but that's not a shocker...
Is this what you bought?
http://www.harborfreight.com/cpi/cta...emnumber=35782
...any suggestions on how to or know any one that has one around the denver area or where can i order one from a web site that is not expensive because i will not be using it on a daily basis. thanks
What's your definition of "not expensive" and what size pipe/tubing are you working with?
I found these (and more) through Google:
http://www.heckind.net/notch/pipenotcher.html
http://www.jointjigger.com/
http://www.lowbucktools.com/notcher.html
I have no experience with these, they're just options for what you're looking for.
Old Feb 26, 2006 | 05:41 PM
yeah that is the one and it sucks. i am working with inch and a half size pipe.
Old Feb 26, 2006 | 06:01 PM
waskillywabbit's Avatar
No such thing as a "good" and "cheap" tool. Try www.tricktools.com as that is where I got my tube notcher. You won't find a better notcher anywhere and the service is excellent.
Old Feb 26, 2006 | 06:27 PM
ROCK TOY's Avatar
Did you use good hole saws? No kidding, I've been using my cheap notcher for 4 years on various projects without much of a problem? Grinder will work, but man it can be ugly if your not careful, plus very time consuming. Most of my notches have turned out great, even the angled ones. Operator error, just kidding. I've mostly used mine on 1.75" .120 wall dom. Maybe try it again with some more patience??? Just a thought
Steve
Old Feb 26, 2006 | 06:51 PM
BruceTS's Avatar
I've used the cheap Harbor freight one for quite some time now and never had any problems with it. I use the bi-metal hole saws and take my time starting the cut....
Old Feb 26, 2006 | 08:37 PM
PirateFins's Avatar
I would suggest getting a set of good quality hole saws, and use lots of cutting fluid so you don't burn them up. My gandpa always said "lubrication is the key to everything in life".
Old Feb 27, 2006 | 05:10 AM
Napoleon047's Avatar
http://www.metalgeek.com/static/cope.pcgi
enter the data, print it out, cut it out, wrap around the tube and trace, cut with your choice of tools and you have a perfect notch
Old Feb 27, 2006 | 05:56 AM
Cebby's Avatar
Chopsaw tube notching:
http://www.offroadfabnet.com/forums/...read.php?t=331
Old Feb 28, 2006 | 05:24 AM
midiwall's Avatar
Originally Posted by Cebby
psssst... hey Mike... OffRoadFab has their forums setup such that you need a login to see anything.
Old Feb 28, 2006 | 05:36 AM
Cebby's Avatar
Sorry about that - kind of sucks eh? Let me see what I can muster for our readers here...
Old Feb 28, 2006 | 05:40 AM
Cebby's Avatar
OK - This was written by Marc Googer and is posted over on OFN (offroadfab.net). Plenty of good info over there for the budding off road fabricator...
Originally Posted by keithxtreme @ OFN
The chop saw method, if understood, is a science. With known tube size and joint angle, tube can be notched with great accuracy. The notch is achieved by cutting two opposing angles on one end of a piece of tube, to form a point. The cross-section of this cut will be an elliptical cut due to the shape of the tube. Changes in both of the two angled cuts must be made for the intersection angle and the size of the two tubes being joined. The only real limitation is the max angle of the chop saw.
You start with what I call the base angle. This is the angle of both cuts if the joint was 90*. For an example, I am fitting Two tubes together that are both 1.75", at an 90* joint. The base angle, or the angle of both cuts is 28*. These two cuts must meet at a point, and the point must also be centered on the tube.
What if I want a 15* joint with my 1.75" tube???? You must start with your base angle, which was 28* for 1.75"(remember above), and subtract 15* from one cut, and add 15* to the other cut to form a perfect notch. So now I must make a 13* cut and an 43* cut with the point centered on the tube. Perfect coped joint, with no grinding.
Remember your base angle will change with the tube being cut and the tube that you are fitting to.
* Here are a few examples of base angles...
* 2.0" to 2.0" tube, base angle of 30*
* 1.75" to 1.75" tube, base angle of 28*
* 1.5" to 1.5" tube, base angle of 26*
* 1.25" to 1.25" tube, base angle of 22.5*
* 1" to 1" tube, Base angle of 20*
* Now to fit different size tubes together
* 1.75" to 2" tube, base angle of 25*
* 1.75" to 1.25" tube, base angle of 45*
* 1.25" to 1.75 tube, base angle of 20*
* 1" to 2" tube, base angle of 12*
kawazx636
Oct 6, 2021 03:03 PM
Firefightersink15
Nov 23, 2015 10:32 PM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
larrys93pickup
Sep 17, 2015 07:05 PM
