Square Drive shaft.
Old Jun 25, 2013 | 07:38 AM
CJ94yota's Avatar
Square Drive shaft.
I know people say to use 2-1/4'' and 2-1/2''. but I just called six different steel shops and none of them have 2-1/4''. And they all said they didn't know where I could find any. So does any body know if 2'' and 2-1/2'' would work. If not, any other ideas on places that would have 2-1/4'' tube. And I know it varies but could someone tell me like an approximate length.
Thanks, guys.
Old Jul 2, 2013 | 10:50 AM
aviation1's Avatar
If the 2-1/2 inch piece had a 1/4 wall thickness then the 2 inch piece should fit nicely.
Old Jul 2, 2013 | 06:00 PM
crankyster_01's Avatar
I just built one this weekend I used 2 1/2 in 1/4 in wall and 2 in 1/4 in wall tube to do mine. Instead of telling them 1/4 in wall they call it schedule 40 square tube. Good luck
Old Jul 2, 2013 | 08:30 PM
toyota4x4907's Avatar
I have always heard people using 2" 1/4 wall and 2 1/2" 1/4 wall. But, instead of just regular ol' 2 1/2", get "RECEIVER" tube, which is slightly larger outer dimension (2.53") and is seamless so the 2" sq tube will slide into it.
Old Jul 2, 2013 | 09:18 PM
BigBluePile's Avatar
^^This. Boom.
Old Jul 2, 2013 | 09:31 PM
Shakalaka
Old Oct 25, 2013 | 11:51 AM
CJ94yota's Avatar
So i got one of those cheap autozone hitch receivers off my buddies jeep, and i made the drive shaft but the shaft end wont come all the way down to the diff. I dropped the t-case an inch and still wont work. I know there is a way to grind something down but i didn't quite get the how to thread on pirate. Any suggestions?
Old Oct 25, 2013 | 01:41 PM
What?
Old Oct 25, 2013 | 09:18 PM
CJ94yota's Avatar
Sorry for not being too clear. I made a square drive-shaft, because I SAS'd my truck and put it up six inches. But when I put the drive-shaft on the truck the the part on the drive-shaft that bolts to the pinion on the diff was about an inch too high. so I dropped the t-case an inch, so it will bolt up now but it binds up when i put it in gear and wont turn the wheels. But I've been reading and searching and reading some more for the past couple hours. And I think I have figured out how to give the double cardan joint more of an angle. But I'm just wondering if going through the work to do it is gonna pay off.
This picture is the method of how I planed on giving the cardan more of an angle. If any body has done this if I could just get some feed back on wether it works or not that would be awesome.
Old Oct 26, 2013 | 11:11 AM
tundup93's Avatar
Just did that the other day. Gave it a lot more angle. Its also easy to do and well worth it.
Old Oct 26, 2013 | 05:31 PM
CJ94yota's Avatar
Did you use the same u-joints or new ones?
Old Oct 26, 2013 | 06:14 PM
Teuf's Avatar
Given your flange angles. The mechanically correct method is a U joint on each end........
Old Oct 26, 2013 | 06:15 PM
Teuf's Avatar
This is on a front end that has had a SAS.?
Old Oct 26, 2013 | 06:29 PM
tundup93's Avatar
I used the original ones they had no play in them at all. And i have enough angle. But mine is sas'd but only the 3 inch kit.
Old Oct 26, 2013 | 06:30 PM
tundup93's Avatar
What did you use to have a u joint on the top too? I wanna that whenever I can get one.
Old Oct 26, 2013 | 07:01 PM
Teuf's Avatar
Ok I did a SAS. I then constructed my driveshaft to fit the front.
Then with further study i found out that this works to a degree but that a U joint top and bottom works better when the flange mounts are parallel.
Upon lifting the rear to compliment the front 3 " SAS, my pinion angle then pointed up to the transfer case flange. I knew no better and drove it that way. I had some vibes (subtle) and an off throttle groan upon deceleration. Further study still, said to run a CV on top when the drive U joint angles up to it. that I did and It sound and feels way better.
I know this is drawn out but google (drive shaft angle toyota pickup.) That will help.
http://i561.photobucket.com/albums/s...psd7c83f57.jpg[IMG][/IMG]
Now U joints on front, both ends. updates n install pics soon.
Old Oct 26, 2013 | 07:03 PM
Teuf's Avatar
chukarhunt
Dec 8, 2019 11:39 AM
jasonty
41
Dec 23, 2018 01:00 PM
pyramid
Jul 30, 2015 10:05 AM
kyletbert
Jul 17, 2015 11:39 AM
msane99
Jul 17, 2015 10:13 AM
