1 Ton Chevy axle swap ?
If im correct it would be 14 bolt rear and Dana 60 front. Unless your doing some hard core crawling or mud bogging or planning on running a 44" tire I would go for it, It would be a can of warms, Axles wouldn't turn with the 22r/re or 3.Slow. Youd need v8 power
Has anyone every heard of a 1 ton chevy axle swap??
It kinda does. My buddy put Dana 60s under his jeep with 2.5 L 4 banger. He is swapping a 350 in it now cause the 4 banger had trouble rolling his 37's with 4.56 gears. Was only getting up to 55 on highway. So power does have something to do with it. The shop I worked we built a zuk with stock 4 banger and 60s and 35s. It did decent in city but 45 was its top speed. We trailered it to comps and trail runs. Power is needed for DD duty. If its a trail rig towed then 4 banger is fine
thanks for the info..
got a 1988 yota i just built.
5inch lift 35s, internal roll cage,roll bar
waiting on lockers and winch in the mail
got in old chevy with 14 bolt rear, dana 60 front , and a 454 chilling in the back yard just woundering if i could swap the axles out some day,
Don't build the Chevy. Who wants to keep pouring gas into a 454, or take a long ride in an a old tow rig?
You can eventually throw those axles under your toy, as stated earlier, people do it all the time, checkout sky manufacturing, they should have some of what u need. You should never have to worry bout axle strength on the trails again (after you get you gearing worked out with the 4 banger power plant).
Thats weird, a 3.4 with 4.55 gears and 33's doesnt get 22 on the freeway. Maybe i should get a bigger more outdated motor that wasnt known ever for getting over 20mpg then ill stick 37" tires under it with big heavy axles. The math just dont add up buddy.
IF your getting 22mpg with that set up, you need to let the Big 3 know how your doing it since they cant get a gas engine 3/4 or 1 ton to get pass 18-20 on highway with stock tires and similar axles
Just hope their assassins are as incompetent as the people that made the Captiva...
Oh and Im sure they all get 30mpg to. Im actually looking into how I can get my brakes to drag more so that I can get better gas milage. I just can't wait to stick an old 460 in my yota and run some 400:1 ratio rockwell axles with 44'' deflated super swampers while pulling a 38 foot toy hauler so I can finally get better milage out of this darn truck.
Flying91
45
Apr 11, 2024 04:39 PM
scottyg486
Jul 19, 2015 05:34 PM
skoti89
Jul 6, 2015 07:45 PM
