1 Ton Chevy axle swap ?
Old Nov 2, 2013 | 04:57 PM
Kris Schonagel's Avatar
Has anyone every heard of a 1 ton chevy axle swap??
Old Nov 2, 2013 | 05:21 PM
dsal_86Yota's Avatar
If im correct it would be 14 bolt rear and Dana 60 front. Unless your doing some hard core crawling or mud bogging or planning on running a 44" tire I would go for it, It would be a can of warms, Axles wouldn't turn with the 22r/re or 3.Slow. Youd need v8 power
Old Nov 2, 2013 | 07:37 PM
ThatGuy1295's Avatar
Has anyone ever heard of google? Yes people do it. Lots
So your saying unless you need them, I would go for it? And the axles will turn just the same with either a 454 or a 1932 friend engine with 3.5 friend power. It doesn't matter how strong your axles are, the added weight will have effect on things but no more then an exo cage. But gearing and tire size will play a part in it all, not how much your axle weighs or the size of he bearings.
Old Nov 2, 2013 | 07:52 PM
It kinda does. My buddy put Dana 60s under his jeep with 2.5 L 4 banger. He is swapping a 350 in it now cause the 4 banger had trouble rolling his 37's with 4.56 gears. Was only getting up to 55 on highway. So power does have something to do with it. The shop I worked we built a zuk with stock 4 banger and 60s and 35s. It did decent in city but 45 was its top speed. We trailered it to comps and trail runs. Power is needed for DD duty. If its a trail rig towed then 4 banger is fine
Old Nov 2, 2013 | 08:19 PM
Ya 37's and 4.56 gears will be way under powered with a 4 banger.
Agian nothing to do with what axle your running.
Old Nov 3, 2013 | 05:13 AM
thanks for the info..
got a 1988 yota i just built.
5inch lift 35s, internal roll cage,roll bar
waiting on lockers and winch in the mail
got in old chevy with 14 bolt rear, dana 60 front , and a 454 chilling in the back yard just woundering if i could swap the axles out some day,
Old Nov 3, 2013 | 07:28 PM
Id just build up the old chevy. Maybe make it in to a tow rig. Just a idea. 454 is powerful, and with 1ton axles, be a great hauler if not a trail rig.
Old Nov 15, 2013 | 10:18 PM
GRINCH85's Avatar
Don't build the Chevy. Who wants to keep pouring gas into a 454, or take a long ride in an a old tow rig?
You can eventually throw those axles under your toy, as stated earlier, people do it all the time, checkout sky manufacturing, they should have some of what u need. You should never have to worry bout axle strength on the trails again (after you get you gearing worked out with the 4 banger power plant).
Old Nov 18, 2013 | 11:37 PM
bigarms23's Avatar
im running a 4.3 cpi a front d60 513 gears and rear sterling 10.25 rear 513s with detroits on 37s and with the factory 88 4runner gas tank i average 15mpg in town and 22 on freeway its do able
Old Nov 19, 2013 | 05:14 AM
Thats weird, a 3.4 with 4.55 gears and 33's doesnt get 22 on the freeway. Maybe i should get a bigger more outdated motor that wasnt known ever for getting over 20mpg then ill stick 37" tires under it with big heavy axles. The math just dont add up buddy.
Old Nov 19, 2013 | 12:45 PM
IF your getting 22mpg with that set up, you need to let the Big 3 know how your doing it since they cant get a gas engine 3/4 or 1 ton to get pass 18-20 on highway with stock tires and similar axles
Old Nov 19, 2013 | 11:22 PM
RobotMoose's Avatar
Wouldn't GM try and kill him for subverting their plans for selling inefficient trucks made with engineering that was new and exciting 60 years ago?
Just hope their assassins are as incompetent as the people that made the Captiva...
Old Nov 24, 2013 | 02:51 PM
skoti89's Avatar
I know plenty of guys rolling around town with one tons, 37"+ tires and the 22re. You're going to hate driving on the freeway, but I don't know if it would be stable at freeway speeds. Who knows
Old Nov 24, 2013 | 07:00 PM
Oh and Im sure they all get 30mpg to. Im actually looking into how I can get my brakes to drag more so that I can get better gas milage. I just can't wait to stick an old 460 in my yota and run some 400:1 ratio rockwell axles with 44'' deflated super swampers while pulling a 38 foot toy hauler so I can finally get better milage out of this darn truck.
Old Nov 24, 2013 | 08:17 PM
SoCal4Running's Avatar
I miss my old 81 1ton with a prepped 454.
Literally could watch the gas gauge go down on the strip as the speedometer climbed!
Flying91
45
Apr 11, 2024 04:39 PM
deepmarsh
Aug 6, 2015 03:44 AM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
scottyg486
Jul 19, 2015 05:34 PM
skoti89
Jul 6, 2015 07:45 PM
