View Full Version : Offroad Tech
Pages :
10
11
12
13
14]
15
16
17
18
- OME 901HD Questions
- Body and suspension lift are done
- Finally.. before and after pics
- Can I do this?
- SuperLift suspension kits - any input?
- Dual shackle inverting - need solutions
- My take on the aussie install today.
- Looking for input: 3rd Gen Expeditionary Truck
- body lift questions
- can you give me a complete list of the ball joint spacer/new coils lift?
- 2 inch roger brown
- Body Lift is done and 33's are on...Thanks go to Roger @ 4Crawler
- 3Gen question about lift.
- where to buy bj spacers and quick discos
- just bought medium OME coils
- 35x14.50x15s - what size lift required?
- shocks?
- picking a lift
- LOCKERS, other mods? TESTIMONIALS? BEFORE AND AFTER STORIES?
- 4crawler diff drop
- Is it 1.5” over stock or 1.5” from butt sag???
- TJM T17 vs T15
- Lift/Tires/Leaf Springs
- Suspension blocks and offroading in a Tacoma
- REAR LOCKER AND 410'S ON THE WAY!! how are the EZ Lockers?
- Tube Doors are on
- IFS Third Removal Question
- Off roading quesiton
- On Board Air FAQ
- Lift Question
- TRD Tundra coils for a 4runner
- CO2 Regulator question
- crossroad on my truck
- rear locker options
- Tubular Steel Doors for an 89 Runner
- Junkyard finds this weekend
- what are the best gears for 33's
- Rear shock Q's 1st gen bj spacer
- 1.5" sus lift for $150.00 COMPLETE
- DIY R&P Insallation
- OH NO! NOISE AND SMOKE from rear diff.
- Air-down...how much in sand?
- Who has a shower in their rig??
- Handling after 2" lift
- looking for a 4 inch lift...
- 4.56's for 35's?
- Choosing a style of lift 2nd gen 4Runner
- Stock suspension vs. Superlift
- Sorry, another BL question.
- 15 degree cant or 30 degree cant?
- All-Pro Adjustable Rear Control Arms on a 3rd Gen?
- Ball Joint Spacers and 32s
- Winch mounting options.
- aftermarket gas tank skid plates?
- My hysteer is finally here
- GenIII Runner Wheels / Tires Question
- Another 1997 4 Runner Rear Question
- Yet Another 1997 4runner Rear Question
- My Custom Snorkle
- TRD diff ?
- What Would YOU Do?
- How do I set backlash on a R&P?
- 3rd generation spacer lift--- HELP!
- Newbie / Downey 3" ifs lift
- Bearing Splitter for Ring/Pinion Instal
- Will Taco Trd Lsd Rear Fit Into My 1997 4runner With 410s?
- 1997 4 Runner Rear Axle Problem,,,locker Recommendations?
- Watts links?
- Lift installed! 9 fingers left too! Mas pics
- Chain VS Tow Strap Question
- Saggy butt resolution
- V6 Lock Right or EZ Locker installation.
- How do you calculate breakover angle?
- Center Diff Lock/4wd Dash Lights problem
- what choices do i have for a selectable locker?
- Thinking of getting SS Boggers..
- what are my options on spare tire racks?
- Question on axle wrap
- spacer lift: topout extender vs preload spacer
- BJ spacers INSTALLED!!! broke the upper bump stop!
- Rancho Vs Bilstein/OME
- Anyone drop the support arms for the rear axle?
- Cross Linked Air Shocks ?
- How depnedable and how well do detroit TruTrac's work?
- panhard drop..
- arb and 31's or aussie and 33's
- Running boards removed-dialup wrng
- question on tires/lift/gears
- Hooking up winch, what am I doing wrong?
- 1st Gen 4" Lift Shock Suggestions
- body lift help for 3rd gen.
- Got OME coils installed!
- Drive shaft vibration, due to rear lift
- I need help with rebuilding the aisin manual locking hubs for 86-95 IFS
- Lift shackles..Where to buy?
- fabtech coilovers on 4runner..
- Help getting rear leaves off-RUST!
- Lift kit opinion
- How Tippy with an SAS
- best place to buy gears
- How does this sound for shocks?
- Best Price on RB 2" BL
- Suggestions.
- need a lift.......?
- low-pro rear bumpstops.
- does anyone make sway bar disconnects for the rear?
- I want bigger tires.
- Sway Bar Packages
- 2nd gen CV boots
- 1st gen diff drop
- What kills U joints????
- Smitty Bilt Bumpers are they worth a ˟˟˟˟˟?
- To lift or not to lift?
- Shock # cross reference
- Axle vents-
- please critique my suspension package I just ordered
- broken front leaf
- Stubbs Sliders as Step bars
- does anyone have pics of this bumper on their second gen??
- what gears do I have?????
- Torsion Bar Color?
- Offroad Solutions
- 94 p/u ECU relocation pictures
- Tube doors
- ome coils what ones to get???
- Dual Battery Installation FAQ
- Trouble Shifting into 4wd
- Clinometer???????
- Birfield eliminator kit
- Steel Wheels
- I need a shock to Match my Downey HD
- 2nd Gen - Daily Driver Suspension
- Revtek / Tokico lift done.
- 31's or 32's
- Coil springs?
- Tundra coils DON'T fit 95-97 Tacos!
- 4wd problem/tranny swap/t-case swap
- More advice!
- OME lift install on '97 Runner
- 6inch Lift question
- I want to see rOcky's SAWs
- OME or Bils Shocks? Downey or OME Rear Coils?
- Tow Ball Hitch as Recovery Point?
- Suspension joints
- 5:29 All pro Gears
- Spacers or new shocks and coils?
- OME coils for 2nd gen.
- Heavy Duty cv's
- Best All Round Tire - incl Canadian Conditions
- Lift question
- 88 4runner. 3 inch BL with 33s.. I KNOW ITS BEEN ASKED 1000000 times..
- planetary gear axle system?
- FROR 2nd gen 4Runner discos...
- sliders
- Canadian Supply of BJ Spacers, Downey Coils, Bilstien Shocks, manual hubs
- Donahoe Coilover Lift the Best - 1999 4runner Ltd ---------------------------
- Most common back spacing and body lift on a 92 Runner
- Max torsion crank and rear lift ?
- BJ Lift or crank the stock torsion bars??
- tacoma e locker in 86 runner?
- where can I get a drop pitmen arm 91 4R
- where can i get these??
- Question for people that have lock-rites..
- who's running a aussie locker?
- Lock Right Identification
- Stupid Noob lol
- budbuilt crossmember is on
- Common 4Runner lift?
- Felt left out not having a winch so...
- IFS Truss - Who makes the best bolt on?
- Hand throttle
- some info on 4x4 please.
- Highly confused on what lift for 1st gen 4runner
- Lift Questions
- 98 Tacoma Lift Question
- LC Springs
- CHEAP On board Air. Inflate & Deflate 4 tires at once
- BJ spacer fit question
- which gear/locker combo?
- front diff removal/install
- What soft top is this?Where do i buy it?
- tapered sleeve for trailmaster kit?
- What would be the best locker for me?
- Synthetic winch line install question
- Best place to put ECU?
- 35's and 3"BL
- Anyone had a problem with the rear axle not bing centered in wheel well on Tacoma?
- Where do you mount yours? (fire extinguisher)
- What would you rather have? (33s + lockers vs 35s + no lockers)
- Just some things i want to know
- Rancho,Downey IFS lift
- ARB Install On 2005 Tacoma-Pics
- anyone buy the offroad kit from hi lift?
- shocks with 3" rear lift
- Tire delima to stay with 33's or goto 36's
- Clearing 35's...
- 4th Gen 4Runner Winch and Grill Guard
- Welded the Rear 3rd Last night
- Check engine light
- what do you guys think.
- Maximize Stock IFS Travel?
- Buick 350 in 85 PU conversion options & help
- Powertax No-slip
- 2nd gen sliders
- New Toy!!!
- Effective vs Equivalent Gear Ratios
- IFS re-gear ??? == HELP!!!!!!!!
- what Rear end
- A.D.D. to manual locking hubs
- Auto Or Manual?
- Suspension sag
- Warn Rockcrawler bumper...
- Want a 6" suspension lift for my 94 runner... does anybody know if one exists?
- 3rd Gen Lift Necessities
- Running deep water and mud..?
- Swing Away Bumper...1st GEN?
- 2nd gen 2" body lift instructions (good ones)
- So You Think You Can FLEX?
- High Clearance Exhaust with All Pro Bumper
- TRD locker in a 1993 toyota 4runner
- coilspacer install in Los Angeles
- Hi-lift near miss today - be careful everyone!
- 37in irocks and IFS
- anybody see this yet???
- one more shock length question :)
- Lift Install Help: WA State
- mini spools
- Getting the rig trail ready!(2nd gen)
- is a 34x9.5 to narrow?
- Street legal beadlocks...?
- budbuilt....done
- 4th Gen. Slider Roundup
- Leaf springs?
- winch ropes
- FJ80 Axle in a second gen?
- Square Driveshaft
- 4runner ROCKER GUARDS
- Flex shots.
- Detroit Truetrac or SURETRAC?
- Help with 94 4Runner
- install help
- TRD E-LOCKER in a 1st gen?
- New tires, OME860's and Ball Joint spacers. (PICS)
- Anyone running 8(+)inchs of lift on 2nd gen.?
- Revtek Lift, OME Shocks-not compatible?
- what do you think about this tow strap?
- Building 10+in. lift 2nd gen. 4runner
- Debate : 33's VS. 35's on 2nd gen IFS
- correct shock travel?
- movin on up
