A.D.D. to manual locking hubs
Old Mar 10, 2005 | 04:21 PM
byron4's Avatar
i have a second gen. 4runner and want to switch the A.D.D. hubs to manuel locking hubs. can I do it myself or is it a major project? how much would it cost total and what are the best hubs to use? thanks
Old Mar 10, 2005 | 04:28 PM
Steveh29's Avatar
It's definitely a do it yourself project. If you've changed brakes or a rotor, you can do it for sure. I did it so long ago that I forgot how much everything cost. I used Warn premium hubs and I believe that's all you need. I want to say I bought a 'conversion' kit with some different washers that sat up against the bearing but didn't need them. Total job took about an hour. If you have a service manual it shows you how to pull the hub plate off. Then you replace it with the hub. I'm happy to scan the pages of the manual if you want.
Old Mar 10, 2005 | 04:43 PM
Corey's Avatar
Co-Founder/Administrator
Look in the Tech section here.
There are a few "how to" articles in there.
Old Mar 10, 2005 | 04:52 PM
96LtdYota's Avatar
here you go....
https://www.yotatech.com/~corey/tech...etal22lica.htm
for warn:
https://www.yotatech.com/~corey/tech.../matt_hubs.htm
good luck
Old Mar 10, 2005 | 06:31 PM
Flygtenstein's Avatar
Adding manual hubs does not impact ADD. The systems are separate.
Swapping drive flanges to manual hubs is quick and dirty.
Old Mar 12, 2005 | 03:05 PM
YeloSub7's Avatar
so where is the best place to buy a pair? Or does anyone have a ari for sale?
jaretstuff
Aug 4, 2015 02:08 PM
defrag4
Jul 31, 2015 10:50 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
